Results 1 to 10 of 20
Thread: Some numbers .. Hardness ?
    Scottsdale, Arizona
    Default Some numbers .. Hardness ?
    Is the hardness number an issue?
    Temp 85
    CYA 65 -76 ( depending on the test,it appears to vary)
    TC 3.6
    FC 3
    pH 7.5
    TA 95
    Hardness 407
    salt 3400
    I added a little acid after the test. Shoudl I add something for the Alk? We had a storm last night that added about an inch of rain water.
    Pool is crystal clear and no growths.
    Other than the hardness, I think all I need to add is women and beer
    can you edit titles ? sloppy typist here !!!!
    Default Re: Some numbers .. Hardness ?
    Your numbers are near perfect (LSI is 0.01 and my improved CSI is -0.11) and for calcium (CH) and carbonate (TA adjusted with CYA) water balance you get a lot of leeway before you run into trouble (some cloudiness has been reported at CSI of +0.75 so that gives you an idea of how far out of balance you have to get to start seeing any problems).
    It is interesting that with your SWG system you are reporting a CC=TC-FC=0.6 since nearly everyone that has an SWG system reports CC=0 all the time. If you trust your test kit, you might want to try shocking your pool with extra liquid chlorine (or bleach), but it's hard to prioritize that against women and beer. You could probably just wait to see if your SWG gets the CC down to 0 (TC=FC) naturally.
    Richard
    P.S.
    If you click on the "Edit" button and then click on "Go Advanced", then you can edit the title as I did in this post.
    Scottsdale, Arizona
    Default Re: Some numbers .. Hardess ?
    Should I try to do anything about the hardness?
    Sorry, when I said that your water balance was near perfect, that means that your hardness (CH) is fine and you can leave it where it is. Also, I wouldn't worry about the alkalinity (TA) either. If you find that you have an upward pH drift over time and need to add acid regularly, then you can consider lowering your TA; otherwise, leave things as they are.
    Richard
    mbar's Avatar
    Ashland, PA
    When you have a SWG, do you not have to keep the minimum chlorine the same as when you don't? The chlorine level of 3.6 is not high enough with a cya of 65 - 76. The minimum should be 5, max 10 and shock 20. THis could be why there is cc of .6
    Northeast PA
    Marie,
    Well, this is a topic of hot debate as parts of this thread shows. Though the thread was mostly concerning the issue of why a higher CYA level is required for an SWCG system, the answers to that question also relate to why a lower chlorine level may be OK in such a system. Most people find that their CC remains at 0 in an SWCG system and I took a poll recently that showed that this is almost true with manual chlorination though some shocking (1-3 times per season) is typical. At least one user with SWCG reported having algae if not following Ben's table, but most found no problem using a lower amount.
    So the jury is still out on this one though I'm leaning towards the belief that the continual shocking of a subset of the water plus fairly even continual chlorine dosing allows one to run at lower FC in an SWCG system.
    Richard
    Scottsdale, Arizona
    Maybe I should play with the setting a little to see how much higher I have to set it to increase the chlorine to 5. It's a new system and I have been running it for 8 hours a day (overnight ) at about 30%.
    I bought a much bigger cell than needed for my pool so I could run a lower setting . Is there a chart available that shows the increase achieved bases on extended run time or higher cell output ? I'll take a look at the manual when i get home but don't remember seeing anything.
    mbar's Avatar
    Ashland, PA
    Thanks Richard, I guess that's one good reason for looking at the water clarity. If your water doesn't have any problems, then the lower level is fine, on the other hand if the water isn't clear, then it might be better to raise the chlorine level to see if clears up, even if there is no cc.
    Northeast PA
    True, but you can't see bacteria! Fortunately, the amount of chlorine needed to kill algae is higher than the level to kill "easy-to-moderate" bugs (bacteria, viruses) up to and including E. coli. So if your pool water isn't developing algae, then it is more likely than not to be sanitized as well, but this obviously isn't a sure bet since you could just be "lucky" about having no algae (algae growth is dependent on other factors such as food sources including nitrates and phophates). At any rate, most users of SWCG systems seem to be operating below the minimums in Ben's chart (they are at around 3 ppm FC at up to 80 ppm CYA which is 0.015 HOCl level) and are still higher than that needed for disinfection (0.011 HOCl level roughly corresponding to 650 mV ORP) and since they are constantly generating chlorine to maintain their level, they are probably safe.
    Nevertheless, I would prefer that the SWCG manufacturers design "longer" salt cells (more surface area so generation rates can be lowered per unit area) or change the internal flow rates and geometry so that they could operate efficiently using a lower CYA level (30 would be great, though even 50 would be much better). They will still generate high chlorine levels for their "shock" effect, but the lower rate per unit area will give the chlorine time to combine with the lower amount of CYA at normal flow rates (into and out of the cell, not inside the cell near the plates, where the flow is slowed down intentionally).
    Richard
    mbar's Avatar
    Ashland, PA
    Is there a problem with running a higher chlorine level with a SWG? In my opinion, if there isn't, then why wouldn't you want to be on the safe side and run the chlorine levels according to the "best guess chart"? I don't understand why people are so afraid of chlorine - it has to be in really high levels for it to hurt you, and bacteria are much more harmful. On the other hand if you go by the look of the water, then as soon as it is cloudy, even if there is no cc, then it would make sense that something is wrong, and more chlorine should be added. Most problems I have seen with pools is the lack of adequate chlorine levels. It is really sad that the media (pool companies) have made people so afraid of using too much chlorine.
    Northeast PA
  1. What is hardness?
    By jerome in forum Dealing with Alkalinity and Calcium
    Last Post: 05-08-2012, 12:45 PM
  2. zero hardness
    By poolgal in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-01-2008, 02:54 AM
  3. Hardness
    By Lil Bit in forum Dealing with Alkalinity and Calcium
    Last Post: 08-16-2006, 10:25 AM
  4. Hardness
    By Lil Bit in forum Pool Chemicals & Pool Water Problems
  5. Hardness
    By Sunny32504 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-25-2006, 11:43 PM
