Results 1 to 3 of 3
Thread: Borax test?
    Jul 2006
    Maryland
    Post Borax test?
    Before I was introduced to this forum, my local pool store sold me hundreds of dollars of "optimizer" (Borax) which was part of my algae eradication because my SWG was set at 0.05% from the time the pool was started (the technician's advice). Now, with regular use of the PS234s, I am keeping all of the parameters balanced, but am wondering how to know if or when I might ever need to add Borax.
    Is there a test kit for this?
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Borax test?
    I use the AquaChek borate test strips...IMHO, they are accurate enough to determine if you have 30-50 ppm borates in the water and they are pretty inexpensive.
    Jul 2006
    Maryland
    Thank you, Evan. Your thread on "the great tetraborate experiment" is what prompted me to post the question. Like you, when I used the borax I noticed a silkiness to the water and a bright sparkly appearance.
  1. taylor test kit and borax
    By shawnw in forum DPD-FAS based testing
    Last Post: 08-04-2012, 09:58 PM
  2. Borax test Strips and cloudy water
    By deep_blue in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2008, 10:30 AM
  3. TA, Borax and Alkalinity test
    By Water_man in forum The China Shop
    Last Post: 05-30-2008, 03:10 PM
  4. How to add Borax
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-27-2006, 01:33 PM
  5. How long to get Borax PH increase test results?
    By famdog in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2006, 02:50 PM
