My dedicated under the concrete deck Polaris booster pump PVC line has got a leak near my pool after 14 years. Probably ice. I am thinking since we have 2 return lines on our 20000 gallon pool that instead of fixing the polaris line, I will run the polaris off the return hole in the shallow end, and then the return hole in the deep end and shut off the return line permanently for the polaris booster pump. Will this be easy and will it also help with the priming difficulty I am having???. Is it a matter of rigging up a disconnectable wall mount to the directional return inlet at the wall???
