Results 1 to 10 of 16
Thread: Where can you buy a line blower?
    Default Where can you buy a line blower?
    I've been told that the kind of air blower the pool services use is hard to find and my high-powered shop vac can't get air through the bottom drain line.
    Anyone know where you can get the right equipment?
    Default Re: Where can you buy a line blower?
    I would think any good sized air compressor (20 gal+) should do the trick, these things ussually put out up to 110 lbs pressure (enough to blow your lines appart) and hold enough compressed ait to fill one line about 5-10 times.
    Connecticut.
    You want to be extremely careful if you attempt to use an air compressor. *Because* they get to such high pressures, they *can* blow up the lines. You really need a high volume, low pressure source to "blow" the air through the lines, whereas the compressor "squeezes" air through the lines.
    I bought my line blower from www.poolsinc.com (search for "line blower"). It was a bit pricy, but well worth it because the big hole in the ground in my backyard isnt going anywhere for a while and it would cost me $75.00 each season just to have the pool guy come out and blow the lines (the chemicals and draining I can take care of myself).
    -Chris
    Thanks Chris. That is what I remember my pool guy telling me about the kind of equipment necessary to safely do the job. I just could never find a source to buy or rent one (and strangely enough, the pool guy couldn't help me with that either). Like you, the line blowing was the only reason why I was hiring someone to close my pool.
    I've been using the discharge end of a 6hp shop vac for years that gets everything but my bottom drain line. It's always made me a little uneasy, though, wondering if I was going to have a little surprise in the spring!
    I've used my Sears shop vac for years to blow the lines out with not problem. True, it does not blow air out the main drain, but I don't see any reason that you would need to do that. The ground (unless you live at the North Pole ) does not freeze down to 8 feet below grade. Typical frost line is 36-42" in most places, so as long as you push water down below that level you will have no problem. What I do after blowing lines is pour a gallon or so of mobilehome antifreeze down the line to further protect it. Then in the spring I just pump it to waste, although it will not hurt much if you get it in the pool by accident. I also pour a gallon or more down each skimmer line after blowing them out.
    Just wanted to let you know that all air compressors have regulators that allow you to ADJUST the air pressure on the output side, I certainly did not mean to make it sound like you should go at it full pressure - I believe I stated that they'll have enough power to blow your lines appart, but, you can turn it down to a trickle if you want, with a rubber stopper bored in the center for the air compressor nozzle to fit as a seal on the line you're all set, and at least with an air compressor, you can put it to tons of other uses, so it's not just one piece of expensive AND overpriced equipment used once a year and collecting dust the remainder of the year. I'm trying to be a little efficient here and give you some bang for your buck.
    I don't really understand why you need to blow the lines out.
    I live in the midwest so it freezes every year. All I do is pump antifreeze into each return line, without removing the water, and when I see the antifreeze coming out I cap off the line and fill the rest with antifreeze.
    The main drain I just pump antifreeze into the line until I see it starting to float out and then just leave it. Antifreeze is heavier than water so it stays in place.
    This way may take more antifreeze, but then I don't have to drain the water below the lines, refill it in the Spring or buy a blower.
    I have been doing it this way for about 12 years now and have never had a problem.
    How do you feed the anti-freeze -through the skimmer?
    Connecticut.
    Our freeze line in CT is 42", but I had the same worries as you about the main drain.
    Considering the main drain would be the only plumbing line I would never replace if it ever broke (waaaaay too deep), Id rather spend the extra $$$ and make sure I take care of it correctly. The blower I bought from Pools Etc. actually launched the water out of the main drain so far that it went thru my (already installed) mesh safety cover. So basically it sent the water 2' above the surface, from 8' down. 10' worth of push is pretty darn good!
    BTW, I used my air compressor (or tried to anyway). I even borrowed a tool that increases air flow (using a venturi effect). I was still not able to push the water thru and out of the main drain. The right tool for the job really is that line blower.
    Re anti-freeze....I dont use any up here. Its been suggested to me, but Ive never thought of it as necessary. However, this year I may throw a little slug of af into each line. I know some people completely fill the lines, but with the line blower Im not worried about making the line completely filled with af, just want some in there to handle the spots where water will end up hiding (low spots, elbows, etc).
    -Chris
    Quote Originally Posted by dbursch
    I just pull the union joint apart by the pump, pour antifreeze into a 5 gallon bucket, connect a small piece of hose to a small sump pump and pump the antifreeze into the lines. Skimmer is the same. When you see antifreeze coming out of the skimmer, cap it off with one of the long crushable skimmer plugs. I forget what the name is.
    Just remember that antifreeze will freeze if you don't mix water with it. That is why I don't drain the lines.
  1. Spa blower overheating
    By edjack87 in forum Pool Equipment & Operations
    Last Post: 12-30-2011, 09:00 AM
  2. Air Line
    By ts8181 in forum Pool Equipment & Operations
    Last Post: 10-03-2011, 09:55 AM
  3. Black & Decker 18-volt Cordless Blower
    By fission7x in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-21-2009, 12:38 PM
  4. Spa Blower or Not ? Would like more from spa.
    By towney in forum Pool Equipment & Operations
    Last Post: 12-30-2006, 01:58 PM
