Thread: How far from pool do return lines go?
    Default How far from pool do return lines go?
    We have a very wet section of grass about 7'x7' but it doesn't start until about 4' from our pool directly out from one of the return lines. Does the piping travel through the concrete around the pool or does it come out and travel underground? Thanks!
    Indiana.
    Default Re: How far from pool do return lines go?
    Quote Originally Posted by kissinger99
    It usually runs under the concrete until it leaves the pool area to go to the filter. It won't necessarily reach the surface directly above the pipe. Sounds like a leak, unfortunately.
  1. Bubbles in return lines
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 05-10-2012, 09:56 PM
  2. Return lines and aeration
    By WaterChase in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-12-2011, 03:58 PM
  3. Air Bubbles in Return Lines
    By dnspade in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2011, 03:05 PM
  4. Air in pool return lines
    By Pool in Carolina Blue in forum Pool Equipment & Operations
    Last Post: 09-09-2006, 10:24 AM
  5. Air in Return lines
    By berardi17 in forum In-Ground Pool Construction and Repair
    Last Post: 07-02-2006, 05:51 PM
