Hi SecondMonkey,
I am also a newbie, but at 2 months worth of pool ownership, am getting less "new" each day. rferral1 has given you some good starting tips.
If you truly have only tap water in your pool these last 3 weeks, then you need to get chlorine in there NOW, about .7 gallons of 6% bleach. Whatever chlorine you had in your tap water initially is long gone, as evidenced by your green water color.
Chlorine is added using plain, unscented bleach - no flower scent, no rain scent, just plain bleach. Most is either 5.25% or 6%, check the label, although generic brands can be lower strength. Still OK to use, but it will make a difference how much you put in. A Bleach Calculator is posted as a sticky at the top of the "Testing and Adjusting Water Chemistry" section.
I would go out and buy a supply of bleach and at least a basic testing kit. Wal-mart, or a similar store, usually has a $12-$15 kit that will test for pH, chlorine, CYA (stabilizer/conditioner), alkalinity, and hardness. Skip any kit that has test strips, you want a drops-based kit.
Test your pool water and post your numbers back here and everyone can then help you get that pool back to blue! Also let us know what "supplies" you've ordered and are considering using.
