Thread: PH is high ....need a little advice
    Jul 2006
    Default PH is high ....need a little advice
    I am kind of new to this pool stuff...and still waiting for my test kit....?????
    In the meantime
    My chlorine has been in good ranges not too high, not too low
    My CYA is a little low (about 27 or 28) i heard it dissolves slowly in the sand filter so dont jump and add more for afew days....yes
    My PH has been rising and is now a little over 8...maybe 8.2
    Hardness is around 230
    My alkalinity seems to be in the range of 100
    Am i correct to add some acid? 17500 gallons...what is a good dose to begin correction?
    IL.
    Default Re: PH is high ....need a little advice
    How did you arrive at these numbers?
    Jul 2006
    Extrapolation....i had the water tested at a pool store a few days ago and came up with the others from a modest quality (add the drops and check the charts) test kit....I feel pretty good about the numbers...what is your concern?
    PS: still waiting for my test kit to arrive...
    duraleigh Guest
    Topnotch,
    I'd suggest you add 1 qt of muriatic. Test the next day and plan to add another quart to get it down around 7.2 or so. Results are a little variable so best to lower with multiple doses rather than a huge drop.
    Download the bleachcalc. It'll help you with many dosage calculations.
    Be on standby to raise your Alk with baking soda, too. Adjust pH first, however.
    How does your water look?
  1. Taking the High Phospate advice and going to get a real test kit, staying tuned
    By dixiefied in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-24-2012, 03:33 PM
  2. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  3. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 11:52 PM
  4. Very High Chlorine, Advice Please?
    By DebPoolClueless in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2006, 12:11 AM
