Thread: Clear lid on pump pot is stuck
    Default Clear lid on pump pot is stuck
    You know how the clear lid on the pump pot says "Do not overtighten". Well, apparently I did. I have been careful not to overtighten but all this swimming has made my arms stronger than I realized. Any tricks for getting that thing off without breaking it? Much thanks.
    Indiana.
    Default Re: Clear lid on pump pot is stuck
    Some have a raised bumps so a 2X4 will fit in to give you leverage to crank it off.
    duraleigh Guest
    rubber mallet (gently)
    Cupertino, CA
    The local Leslies has a tool for exactly this purpose. In fact there are two versions: one plastic, one metal; called a "Pump Lid Removal Tool".
    I keep a 10 inch length of PVC pipe down near the pump, when the lid ring sticks, I tap it gently around the perimeter while using the other hand to unscrew it or at least create torque in the unscrew direction, 3-5 taps and it's off.
    If the clear lid under the ring is stuck, look around the edge carefully, there will be about 4 little slits on the underside, you can put a flathead screwdriver into one and twist, this will break the suction seal and let it come off.
    MaryLee is offline Registered+ Thread Analyst MaryLee 0
    Southern New Hampshire
    Mine always sticks too. I have a thin piece of pipe I keep near the lid...I just put it through the handle and twist gently....always comes off without a problem. Hope that helps..
    18 X 40 IG Vinyl
    3 1/2' ft to 8' deep
    Pentair DE Filter
    400K BTU Pentair Minimax heater
  1. Stuck with Caribbean Clear
    By dont1ab in forum Dealing with Algae & Slime
    Last Post: 08-06-2012, 02:38 PM
  2. Super Clear sand filter and pump
    By slssol1 in forum Pool Equipment & Operations
    Last Post: 06-21-2012, 12:46 AM
  3. Pump basket lid stuck
    By cmcq in forum Pool Equipment & Operations
    Last Post: 10-02-2010, 08:25 PM
  4. Air in system won't let pump hold pressure (Skimmer weir stuck)
    Last Post: 07-05-2008, 12:53 PM
