Results 1 to 10 of 38
Thread: DIY woes!
    Jul 2006
    South Dakota
    Default Re: DIY woes!
    Getting water to the filter is no problem. I can use the main drains. The problem is returning the water back to the pool.
    But thank you for your response.
    Talking Re: DIY woes!
    sjk, welcome to the forum, this thread's a hoot! (I love the comment on drinking and putting up the fence, I'm the same way with sheetrock )
    What you should be able to do is fill the pool to just under 1/2 way up the light, install the faceplate and cut it out so that the electrician can get to what he needs to. At this point, the water should be high enough to do the returns (but not if they are too close to the corners - if the corners are 'loose' ie, liner not tight on them, and the return is within ~5', you could develop a huge wrinkle by putting the faceplate on without the water being all the way up) [there is a way to do it but you'd need 2 people]
    As for the green water, put some bleach in there, circulation is a good thing but clean water is more important - just add it to the stream from the hose, it'll mix up enough.
    If you think a wet liner is slippery, try it with a nice coating of algae
    Again welcome to the forum, thanks for the HA-HAs, if I can be of any help, please don't hesitate to ask! - Waste
    Honesdale PA
    Until you open the return lines can you jury rig the waste line from the filter to dump it over the edge of the pool? Would at least get circulation.
    Jul 2006
    South Dakota
    needless to say the returns are by the corners. I have been adding bleach but have not done a reading yet. the water has not hit the break point and i have no desire to try to reach over it and chance sliding in. that stuff is dang cold. I dont think the boys would apprecite the rush of cold water. ( the guys will understand what i mean)
    Jul 2006
    South Dakota
    alrighty. Update time. When I got home i had two inches in the shallow end. Had to put the flanges on the stairs. Oh man did that suck. that water is cold!! my toes are pretty pissed at me. Took forever to get all those screws in. Im telling you all right now. I will never do this again.
    on a side note. shop vacs do not like to run for extended periods.
    would not bother me if it was mine
    Jul 2006
    South Dakota
    ok where to start this update?
    Well we started plumbing in the pump, sand filter, and heater. Sent the little lady into town for some sand and a propane regulator. Told her no matter wat dont buy anything from the pool store but the sand.
    While she was getting the regulator she saw that bleach was on sale for 89 cents a 3 quart jug. She could not pass that up. she bought 36 jugs
    then she heads over to the pool store and as they are loading the sand they see all this bleach and freak out on her. the salesman starts telling her it will destroy her pipes and liner. That in no way could she use bleach. It took me over two weeks to convince her bleach was safe for our pool and 3 mins for him to tell her it was not.
    Needless to say she calls me on her way home to tell me all this and that she bought $50 dollars worth of shock and algacide. Of course I was not the least bit amused by this. I dont blame her, she is just worried about the investment we have put into this project. As soon as she got home I made the call to the salesman. Asked him what gave him the right to tell her it would ruin her pool. he goes on and on how it is not the same ingrediants as pool chlorine. I told him he better read the bottles on both. Then he tells me that i will have so many problems with my ph and that it will cost me lots to keep it balanced.
    I told him that i will worry about my pool. I also told him that we were planning on getting a hot tub next but after this crap that the only time i will ever go to his store is to return this stuff. I also told him that I liked how he did not give her a reciept. Nice try on not letting her bring it back. I informed him that i will bring it back myself. He said that was ok and if I want to destroy my pool that was my choice.
    he sold her some bioguard burnout 35. its active ingredient is lithium hypochlorite. the little lady wants to know if this would be ok for a one time deal?
    also he sold her some bioguard algicide 28-40. active ingredient alkyl(c14 58%, c16 28%, c12 14%) dimethyl benzyl ammonium chloride 40%. what is this?
    now for my other problem. we have a hayward 300lb sand filter. the winter drain leaks. I figuired that maybe something got inbetween the seal. so i went to pull it off and reseat it. well come to find out the cross insert in the drain was put in wrong so it is not flush. now i have a leak and am not sure how to stop it. It is clearly a manufactures defect. the problem is that it is all hard piped in. does anyone know away to stop this leak without sending the tank back in without delaying this project any more?
    Honesdale PA
    Steve,
    Similar issue here with the 300# Hayward installed in 97. Only in my case they left out the short lateral that keeps the sand from dumping out when you drain. What a surprise on the first winterization drain. I'd recommend draining the thing, clean the threads with a scrub brush so no sand is in the threads, then goop the cap with silicone seal and put it back on. Make sure the soft seal, whatever the material is, is inside the cap. Oh, and on my problem, I made a short lateral from a piece of PVC pipe and cut slits in the thing. Quicker and a lot less hassle than dealing with Hayward or the company that redid my pool after I inherited the thing with the house. Don't interpret this as a knock against Hayward...I just did an easier fix that worked.
    Jul 2006
    South Dakota
    ok everything is now at a stand still. The pump is running. I have a temporary return line in. Here is the problem. I cant finish filling till i can cut out the light and have that wired in. the problem is that our electrician can not track down a junction box rated for pools. (wet locations) The state inspector says this is one of the things South Dakota will not budge on. Oh fricken great. so here is how this all works. I cant swim because the water is to cold because the heater is not wired. the heater is not wired because the light wont pass inspection. the light is not wired because my electrician cant find a junction box and some seal crap for the niche. my returns are not running because of the light. And to top it off. WE ARE RUNNING OUT OF NICE DAYS!!!
    Would anyone know where i can get this crap from shipped overnight?
  1. Plaster Woes!
    By txhomebrew in forum In-Ground Pool Construction and Repair
    Last Post: 04-23-2012, 03:11 PM
  2. Above ground woes :(
    By hummingbird_0414 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-04-2011, 10:29 AM
  3. Winter Woes!
    By scsteven in forum Above-Ground Pool Construction & Repair
    Last Post: 05-16-2007, 07:21 AM
  4. Oh Man....liner Woes
    By topnotch in forum In-Ground Pool Construction and Repair
    Last Post: 08-03-2006, 08:35 PM
  5. Pump Woes
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 06-12-2006, 10:15 PM
