Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 38 of 38
Thread: DIY woes!
  1. #31
    Mandeville, LA, USA.
    Default Re: DIY woes!
    Quote Originally Posted by sjkader
    ...talk to the general manager and he does not even know how to install the lines. I'm telling you guys. This general manger is one heck of a winner. Im pretty sure his family tree dont branch. I got so fed up talking to him that i decided to unleash the bulldog on him. Oh thats right! He will regret this! I'm having the little lady call today! he is the walking dead right now and doesnt even know it!
    Update later after the brawl
    His name isn't Buck Strickland, is it?
  2. #32
    Jul 2006
    South Dakota
    ok the propane company fought tooth (only has one I'm sure) and nail, but have decided to come out and change the line out. We will pay the diff. from the 3/8 to 1/2. they have already been out and replaced it and they will come out mon to dig up the old line and trench in the new one.
    score one for the home team!!
  3. #33
    Jul 2006
    South Dakota
    Here is the update for the weekend!
    WE pretty much did not get anything accomplished. Friday we fired up the heater after the propane guys left. It now works the way it should. Spent from 10pm to 3:30 AM in the pool. Had it set to 95 degrees just to see how nice that is one time. The kids were all gone so it was Alone time
    Saturday all kids were home. left the heat up to 95 so thay could at least feel it that high once. Wow what a blast.
    now that the week is here again time to get that deck done. I also have one return line that leaks that i need to cut out and replace. Should get to that this week. Plan on keeping the pool heated at about 87 degrees for a couple weeks then close it down. its been in the 60's here but when you hit that 87 degree water its like swimming in the bath tub.
    more to follow.
    Im also trying to figuire out approx. how many gallons it is. it is an 18 X 36 rect. the shallow end is 3'4" and extends nine feet then the breakpoint starts and runs to a nine foot deep end. I have run the numbers different ways and come up with something different each time. Any help would be appreciated.
    ps. cut my little toe open running to the pool. No stitches needed this time
  4. #34
    Thanks for keeping us up to date, I know I'm only one of many that have truely enjoyed this thread!! With reguards to the volume of your pool, I'd guess ~23,000 gal without 'crunching' any numbers. I've said before (but I'm too incompetent with the computer to save myself time by linking) that unless you hook up a watermeter while filling, you'll only have a good guess as to the actual gallonage. The real trouble with the computation is the 'average depth' and that # is a 'guestimate' (and the multiplier - I've always used 7.5, but it's actually closer to 7.49), so unless you can break the pool down into simple solids, who's volume can be easily figured, and add them all up, you end up with a 'fairly' approximat estimate. The real point here is that, it really doesn't matter. As long as you are 'in the ballpark', the recommended chem levels are forgiving enough so you can safely dose your pool. When dosing the pool always 'lowball' your estimated volume, you can always add a little more of whatever, but getting some of them back out can require other chems and some work. In practical, for you, terms, treat your pool as if it were 20,000 gal and shoot for the lowest increase or decrease you can - with a little experience with your pool, you'll learn what a gallon of bleach does or what 2 lbs of baking soda will do. Best of luck with the deck - and thanks for the giggles! - Waste
  5. #35
    Jul 2006
    South Dakota
    Not sure how many are still following this thread but here is an update!
    Not much is getting finished. every time we go out to work on it we end up swimming
    Have been getting quotes on the decking. we are going a min amount on concrete then next year will do decrotive brick around the concrete. I just want the diving board in before we have a giant ice cube in the backyard.
    The electrician came out and made all the temp lines permanent. while doing so he managed to break off the heater ignition module. Did he notice it? Heck no! or he did and did not say anything. either way i rigged it so it will work for the time being. I dont know if any of you have ever been to South Dakota but right now is not ideal swim season without a heater. Went through our first tank of propane. We will go through one more before I give up the battle and close it down.
    Have had the pool up to 95 a couple of times. Its like swimming in your bath tub. have to love that.
    The only real bad thing is getting out and covering the pool. man oh man is that dang cold. pretty sure i keep freezing something important
    Thats the update as it stands now!
  6. #36
    mbar's Avatar
    Ashland, PA
    So glad that you are taking the time to enjoy the pool I am closing mine tomorrow. You will get the rest finished in time, but at least you didn't miss out on the fun now - Keep a big fluffy towel nearby to keep you warm when covering the pool - or get one of the swimmers to heat your towel before you get out, after all if you are the one who has to freeze, it's the least they should do!
    Northeast PA
  7. #37
    Jul 2006
    South Dakota
    Update!!
    Called a few concrete companies to come out and give quotes on the decking. Right now we are just going with a standard concrete deck. Min of 5' all the way around except where the diving board is. That section will be 8' as required in the directions. We fig if we do this atleast we have some barrier between the dirt and our crystal clear water.
    Most of the companies we talked to said they would not even deal with it. they are afraid to spill concrete in the pool. OK no big deal. If they dont want my money, Ill just have to get over it One company quoted 3500 to form and pour. Oh man sticker shock. Then A friend told us to call this other company. This other guy comes out. we tell him what we want. he says no problem ill write you a quote right now. goes out to his truck comes back in about ten mins with a quote. 2300 then proceeds to tell me what that will get me. first he will finish the grade. then form and set rebar. next day he will come out and do the pour. where we need about a foot retaining wall, he said he will just pour a concrete step down. then he says since he will have his bobcat here, he will finish moving our top soil and get it ready for us to seed. All this for 2300. The only question the little lady had for him was "WHEN CAN YOU START?".
    He starts wednesday.
    It will be so nice to stop looking at p-rock and dirt.
    Ill try to get some pics of the yard. Before, during, and after posted sometime this week.
  8. #38
    Jul 2006
    South Dakota
    here is some pics. I hope!
  1. Plaster Woes!
    By txhomebrew in forum In-Ground Pool Construction and Repair
    Last Post: 04-23-2012, 03:11 PM
  2. Above ground woes :(
    By hummingbird_0414 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-04-2011, 10:29 AM
  3. Winter Woes!
    By scsteven in forum Above-Ground Pool Construction & Repair
    Last Post: 05-16-2007, 07:21 AM
  4. Oh Man....liner Woes
    By topnotch in forum In-Ground Pool Construction and Repair
    Last Post: 08-03-2006, 08:35 PM
  5. Pump Woes
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 06-12-2006, 10:15 PM
