I have a Pentair Pinnacle pump that has developed two casing leaks at the curved "shoulders" of the main housing, just below the vertical discharge. The first leak was a seep that appeared a year+ ago & was small enough to initially ignore. Last week the other side started a pinhole squirt shooting a few feet out.
The pump performs real well otherwise so I'd like to repair it. I opened it & saw no obvious internal damage, so I'm assuming it's a porous casing problem. I tried epoxying over the leaks, first using the 2-part "J-B Weld" brand & then buying some from my pool dealer, a "Weld-On" brand stick 2-part epoxy. I sanded & cleaned the surface each time & kept the pump off 12 hours to cure, much longer than the directions on either epoxy called for.
I stopped the squirt, but water on both leaks has found a path out to the edge of the epoxy. While each epoxy was strong enough, neither bonded to the casing sufficiently to keep the water from finding a path between the epoxy & the casing.
Any recommendations for a patch that will bond to the case? Thanks.
