Thread: Is it possible pool store adds stabilizer to sodium hypochlorite?
    finch Guest
    Default Is it possible pool store adds stabilizer to sodium hypochlorite?
    I'm trying to figure out how I ended up with high stabilizer levels this year. I am getting a reading more than twice what I should be getting for the level of cyanuric I added in spring. I use only sodium or calcium hypochlorite, generally 10% sodium from the pool store.
    One possibility is that I had false readings in the cool spring weather/cold water.
    I am also wondering, though, whether it is possible that the pool store adds some cyanuric to the sodium hypochlorite tank. Has anyone ever heard of something like this or am I being silly? Could I dilute the chlorine to a certain level to reliably test it straight from the bottle? I wouldn't think testing it undiluted would be possible.
    Default Re: Is it possible pool store adds stabilizer to sodium hypochlorite?
    I don't think they can do that.
  1. Percentage sodium hypochlorite?
    By Mindiv in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-06-2013, 04:31 PM
  2. 6% sodium hypochlorite vs. 68% calcium hypochlorite for start up?
    By Mtheuck in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-07-2012, 10:44 PM
  3. Sodium hypochlorite and PH levels
    By Manslick in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-14-2011, 02:13 PM
  4. Compare Calcium and Sodium Hypochlorite
    By jereece in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2006, 01:51 PM
  5. BBB method With Sodium Hypochlorite???
    By mikeydiker in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2006, 04:28 PM
