Thread: Frequency for adding Sodium Dichlor ?
    Default Re: Frequency for adding Sodium Dichlor ?
    I think you will find that most members of this forum, me included, would recommend getting rid of the Nature 2 (or at least NEVER letting your free chlorine drop below 2 ppm! Recent studies on kill times for water borne pathogens done by the Austrailian government support this! They now require all copper/silver systems, including Nature 2 be used with NORMAL and NOT reduced Free Chlorine levels).
    Also, using bleach (same as liquid chlorine) for chlorination is cheaper and will not cause your pool to be overstabilized. You need to maintain a stabililzer level of 30-50 ppm.
    Thanks Bear. Do you have any further information (internet link, etc.) on the Australian govt study on water borne pathogens and need to run Nature 2 system at higher chlorine levels. I am new to this and my pool guy had indicated I should keep chlorine no greater than 1.0 ppm for ideal operation with Nature 2. thanks
    Thanks WB. Given my new pool has Nature2 am I best off keeping chlorine > 2 ppm or just abandoning (in favor of what??). Thanks for any suggestions.
    If it were my pool I would ditch the N2 and just use bleach or, better yet, install a SWG.
    Tennessee
    I was told the same for pool care by the store and after finding the form and thinking about it I ended up ditching the N2 system. If you are in for a read about it you can take a gander here.
    http://www.poolforum.com/pf2/showthread.php?t=405
    I was out about $80 to $90 a month on chem and if I used the N2 about $110 a year for the N2 before finding the forum. Last month I spent $29 on chems for the pool. Most pool stores are out to dig deep in to YOUR pockets and sell you magical products. I was pool stored for $425 when I bought my pool. Listen to the pros here they know what they are talking about. They will save you money and give you great advice to have great water.
    Waterbear as useual I dont include you in the above statement.
  1. What PPM Sodium for non SWG pools when adding salt?
    By mjs31 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-24-2007, 03:37 PM
  2. Adding Bleach - frequency?
    By BarryY in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 11-08-2006, 05:55 PM
  3. Sodium Dichlor triazetene???
    By chemistrydropout in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-03-2006, 05:23 PM
  4. CYA present in sodium dichlor?
    By poolgal13 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-14-2006, 02:33 PM
  5. Adding sodium bicarbonate AND calcium chloride at the same time
    By thr56 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-23-2006, 03:03 AM
