I have been using Ben's kit all summer and have been quite happy. It is so great to know what the CC is! I'm sure I've saved a ton on chlorine.
Pool has been running well all summer, but in the last two days it has started a slightly bluish cloudiness - not greenish like algae. I know I have high calcium and high alk, wondering if this is finally having some effect.
I do have scale deposits on the pool walls and have had all summer.
Suggestions please:-)
26,500 gal IG vinyl lined pool
FC 4.5
CC 0
TC 4.5
ph 7.8
alk 160
cal 210 (or more - not sure how "blue" the sample is to turn. I stopped when it turned just past reddish hue into a bluish hue)
cya 30
water Temp 76 (we've had a cool spell with freezing at night. Life in the mountains!)
I haven't messed with alk because my ph doesn't tend to creep up. This is the highest it has been all summer.
My plan is
1) do Ben's alk reduction process using muriatic acid, to see if pulling the alk down closer to 110 may help, then keep ph at the lower end of 7.4.
2) keep the chlorine level up at 5.
Not sure if I need to mess with calcium due to scaling.
Thanks for any help!
