Thread: I think it's finally all DEAD :)
    Jul 2006
    Middle of the mitten , Mi
    Talking I think it's finally all DEAD :)
    Water is finally looking like it was last year , yaaaaaaaaaaaa !
    The pool looked great but every time I back washed the sight glass turned green , not good . Rope on my weight jugs were getting a slight green tinge etc , not good . Water checks were good . I first changed the sand in my filter , I had this spring put alot of junk off the bottom in there by not vac to waste . Two days later I backed washed to more green in sight glass , NOT GOOD again . Was telling my daughter all about my troubles and she asked if I ever put the bleach in the skimmer box ? I said NO , I didn't think you're suppose to do that . Later as I got madder , I went ahead and added that days bleach to it all 3 quarts slowly in the skimmer box . Filters been on 24/7 since having more problems . Next night , guess what NO GREEN . Been three days now and backwashed again this morning and NO GREEN again . Also the very next day after adding that bleach to skimmer the ropes etc had lost their slight green tinge etc .
    One thing that I should add , I never gave the pool enough time to get the CC to 0 as my Daughter and Granddaughter are here from Norway for only 2 weeks and it seemed that every time I was seeing green it was toward the weekend and we all wanter to swim . So if I had done it the correct way I think it would have not shown up again . I did bleach shock to 23.5 for about 29 hours , no green but CC still was 0.5 .
    Anyone else ever done this ? As a new member to forum I have not read about it yet .
    Also as it looks like I really have control of the pool again so I put the filter on timer again .
    I usually add clorine at around 5 pm or so any ideas to a good time for on and off ? I am useing 11am to 7pm now with a hour in the middle of night at 3am to 4am . Would like to know better way if there is any .
    Thanks again for this BB board , my pool costs are so much less now and I don't feel like taking a AXE to the pool anymore , hehe . That's no joke btw .
    cheers
    Sanford, FL
    Default Re: I think it's finally all DEAD :)
    It is usually recommended that you keep the shock levels until you can keep chlorine overnight - CC level means that the chlorine is still fighting something that you cannot see. This means that by prematurely lowering the chlorine level - you could still end up with an algae bloom.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Jul 2006
    Ok , will shock till the CC is 0 , will start this Sunday then . Daughter and granddaughter go back home that day .
    Thanks for replying .
    cheers
  1. Finally got Ben's kit! First results....
    By court475 in forum DPD-FAS based testing
    Last Post: 09-12-2006, 04:49 PM
  2. I finally tried my aquabot...
    By gonefishin in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-15-2006, 01:02 AM
  3. Finally!! I see progress!!
    By poolmom06 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2006, 09:49 PM
