Hi. I'm interested in getting feedback from you folks on a quote I received for an inground pool. I feel that the quote is slightly incomplete, and a little on the high side. I know that the cost of materials has risen substantially in recent years, however, my budget hasn't.So here it is.
ONE 16’ X 40’ RECTANGULAR SHAPED STEEL REINFORCED GUNITE CONCRETE POOL WITH DEPTHS OF 3’-6” – 5’-0”.
SOLID 6” X 6” FROST PROOF TILE AT WATERLINE.
GREY MARBELITE FINISH ON INTERIOR OF POOL, HAND TROWELED TO A SMOOTH, NON-SKID SURFACE.
WALK IN STEPS IN SHALLOW END CORNER.
TWO 500-WATT UNDERWATER LIGHTS.
DUAL MAIN DRAINS, TWO SKIMMERS, THREE RETURNS, AND POOL SWEEP LINE.
HI-RATE SAND FILTER TANK WITH 2” MULTIPORT VALVE AND 1 H.P. AQUATECH 2-SPEED PUMP.
MAINTENANCE KIT AND VACUUM KIT INCLUDING 8’ - 16’ TELESCOPIC POLE, POOL BRUSH, SKIMMER NET, VACUUM HOSE, VACUUM HEAD, THERMOMETER, SKIM VAC AND WATER TEST KIT.
EXCAVATION, BACKFILL, AND ROUGH GRADE.
ALL SYSTEM PIPING TO BE TYPE I SCH 40 PVC WITH SOLVENT WELD FITTINGS, NSF APPROVED.
PRICE: $34,600.00
OPTIONS:
- SALT GENERATOR (Goldline) $1,500.00
- POLARIS AUTOMATIC POOL CLEANER (no idea) $1,200.00
- NYLON MESH WINTER COVER $1,450.00
- GOLDLINE CONTROL SYSTEM WITH IN HOUSE WIRELESS REMOTE $1,650.00
- 12” X 2” THICK BLUESTONE COPING $4,800.00
*PRICE EXCLUSIVE OF ELECTRICAL, GAS HOOK UPS, ANY VENTING OR PIPING NECESSARY FOR HEATER UNIT, AND WATER TO FILL POOL.
I feel like the plumbing and electrical details should be spelled out further. Any suggestions as to what I should find out that's missing? Thanks all.
Chris
So here it is.
