Thread: How to prep pool for a week away
    Jul 2006
    Default How to prep pool for a week away
    This is my first year with a pool so still learning. I will be leaving for a week on vacation. The pool will have zero attention while I am gone. I want to make sure my water stays ok. Looking for suggestions.
    Default Re: How to prep pool for a week away
    You might be able to get away with shocking it the day you leave and the day you come back, or you may need to put a couple of trichlor pucks in a floater, but it'll depend on your water chemistry--can you post numbers for pH, alk, and CYA?
    Jul 2006
    Thanks for the quick reply. I only have test strips for now (I know I need a drop kit and intend to get one). The strips show ph 7.5, alk 180, cya 30-50.
    With those numbers, I think if it were my pool I would shock with bleach the night before I left, and leave a couple of trichlor pucks in a floater that was tied so it won't float to the edge of the pool. It ought to be okay when you get back, and it won't up your CYA considerably.
    Jul 2006
    Thanks. I will give that a try and see how it goes.
  1. Site Prep possible above ground pool buy
    By Ccfd48 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-09-2012, 01:05 AM
  2. spring prep and a new pool owner
    By mogwai in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-06-2012, 12:23 PM
  3. pool prep for paint question
    By rtate in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2010, 12:11 PM
  4. Closing Pool - Prep for Next Year
    By Skillset in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-08-2007, 08:08 PM
  5. SWG Install Prep ?
    By Hobetx in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-10-2006, 12:05 PM
