First, your pool is probably no more than 18000 gallons using the standard formula: 13*32*6 (ave depth) * 7.48 = 18670. But usually, steps and curves at the bottom reduce it further so it could very well be 18,000.
Second, this should probably be posted in the pool equipment & operations section: http://www.poolforum.com/pf2/forumdisplay.php?f=144
For 18000 gallons, a 3/4 HP motor is more than enough. However, if you have a spa, water features or a vacuum, it may not be enough so a 2 speed would be better.
