Results 1 to 10 of 21
Thread: Cloudy Water & CL Going Going Gone
    Jakebear is offline Registered+ Thread Analyst Jakebear 0
    Jul 2006
    Pennsylvania
    Default Re: Cloudy Water & CL Going Going Gone
    OK --- Here goes nothin' --- NO swimming tomorrow though -- I still don't buy it's healthy!!!
    mbar's Avatar
    Ashland, PA
    Read this post:
    http://www.poolforum.com/pf2/showthr...hlight=dangers
    Read them all, especially the one by Pool Doc
    Northeast PA
    duraleigh Guest
    Hi, Jake,
    Our family swims all the time at shock level. It has actually improved my son's grades. He's (we call him "three-hands") at the top of his class in Computer Science....his keyboard proficiency is astounding.
    Seriously, no one should do anything they're not comfortable with but the ppm of chlorine in pools is amazingly low. When you wash your clothes and add Clorox, the chlorine ppm in the machine approaches 200ppm as nearly as I can figure.
    Mandeville, LA, USA.
    I think you've gotten sound advice from Marie (mbar) and Dave (duraliegh) on shocking your water because of the high overnight chlorine consumption you're experiencing, but I wouldn't overlook the cal-hypo as the possible cause of your cloudy water. Cal-hypo can cause cloudy water temporarily and because you've been adding it regularly, it could well be the culprit here (for the cloudy water only, not for the chlorine consumption). Try bleach as your chlorine source instead and see if the cloudiness problem is ameliorated or eliminated.
    duraleigh Guest
    Hmmm. Good catch, Kurt....that's a good thought.
    Jul 2006
    Pennsylvania
    Dave --- last time I climbed into my washing machine, I “Got all shook up” so I don’t do that very often any more.
    Thanks to all for the responses.
    Just for grins we visited three pool stores today (See my post on CC testing) and believe it or not one of them mentioned the Cal Hypo and told us to turn off the pump over night to let it settle and then vacuum.
    My free chlorine level only dropped .5ppm last night but was still cloudy this morning. We put 5 pounds of K-MPS in before we went to town. It was pretty clear after 5 hours of circulating while I was gone. I will probably shock tomorrow anyway --- bought bleach today.
    Yes, good catch Kurt. I hadn't been really following this thread but when I saw cloudy and cal-hypo and suggesting swimming at 20ppm...well, I had to look.
    Quite frankly, I would NOT swim when keeping the pool at shock levels. If you look at Ben's writing, he's kind of iffy about it. What he's very CLEAR about is that higher levels of chlorine aren't an issue if they are the residual level for the CYA put you there--if your CYA is 120 and your FC is 12, go swimming. But at shock levels? I don't think that's what he meant.
    I noticed the calcium level wasn't posted. I'll bet it's now through the roof. Each time you add a mass of Cal-hypo you may get clouding. If that IS the cause and NOT an excessive calcium level then a good dose of muriatic acid should clear it.
    Meanwhile, switch to bleach/liquid chlorine instead.
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
