Thread: Chlorine level drop
    Jul 2006
    Shepherdsville, KY
    Default Chlorine level drop
    My test results last night:
    8:00 pm
    FC: .5
    CC: 0
    TC: .5
    PH: 7.5
    ALK: 140
    CYA: 30
    I dumped in 2 gallons of 5.25% bleach and tested again 1 hour later:
    9:00 pm
    FC: 3
    CC: 0
    TC: 3
    PH: 7.5
    ALK: 140
    CYA: 30
    This morning I tested and got the following results:
    7:30 am
    FC: 1
    CC: 0
    TC: 1
    PH: 7.5
    ALK: 140
    CYA: 30
    Is the chlorine level supposed to drop that fast from last night to this morning, or am I doing something wrong? Also, I run the pump at night and turn it off during the day and don't add any chlorine during the day. Is this ok? Should I be adding chlorine in the morning instead of the evening when I get home?
    duraleigh Guest
    Default Re: Chlorine level drop
    A chlorine drop of 2ppm in a 24 hour period is pretty normal (organic material, etc. is constantly entering your pool)...some pools use a little more....a few, less.
    Running the pump at night is fine. I also prefer to add the Cl at evening time....it's when it's the most effective. I would suggest adding enough Cl to get your pool to 5ppm and then readding when it gets to 3ppm. That'll keep your Cl in the suggested range on the "best guess" table.
    Jul 2006
    Shepherdsville, KY
    Thanks Dave!! I will try to keep it a 5 ppm.
  1. Chlorine drop ?
    By FNC1962 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2012, 08:41 AM
  2. Liquidator -- how much drop in feed as chlorine is used?
    By lalittle in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-11-2011, 07:00 PM
  3. Chlorine level doesn't want to drop
    By bhc33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2011, 10:57 AM
  4. How much should chlorine level ppm drop?
    By smallpooldad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-20-2008, 05:58 PM
  5. Chlorine level drop quickly
    By jdw-tx in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-27-2007, 08:00 AM
