Thread: Using backwash hose ?
    pool newby is offline ** No working email address ** Thread Analyst pool newby 0
    Default Using backwash hose ?
    Ok, I had to drain off some water from the pool, due to a couple of days hard rains, and decided to use the backwash hose to direct the water away from the pool wall and into a nearby drainage ditch. Is there a secret to keep the backwash hose attached to the multiport drain stub ??? The thing kept popping off sending water everywhere (especially with pump on high speed), and I've had to struggle to hold it on, Makes it hard to watch the water level on the skimmer and get it where it needs to be.
    thanks
    Bob P
    pool newby
    Smile Re: Using backwash hose ?
    you have to use a clamp just like all your other hose connections get one at the hardware store 1$ or so use a screw driver to tighen but not to tight to break the plastic that should do it!!!
    Duanesburg, NY
    Default Re: Using backwash hose ?
    I've got a stainless steel hose clamp on mine, but I bet those thick rubber bands they wrap bunches of broccoli up with would work too.
    C.
    Hose clamp, duh ?? I musta woke up stupid this afternoon (on midnights). I've got an unopended package of them out in the storage room.
    Thanks,
    Bob P.
    pool newby
    Duanesburg, NY
    Quote Originally Posted by pool newby
    Thanks,
    Bob P.
    pool newby
    Sounds like you could use some more broccoli too.
  1. popped backwash hose near end of hose
    By Gretzky99 in forum Pool Equipment & Operations
    Last Post: 05-22-2013, 10:30 PM
  2. Tired of the backwash hose hassle!
    By Redtruck06 in forum Pool Equipment & Operations
    Last Post: 06-15-2011, 09:01 PM
  3. Backwash hose leaks at top connection
    By ellry99 in forum Pool Equipment & Operations
    Last Post: 07-05-2008, 11:10 PM
  4. Backwash hose ideas??
    By Pool_Mike in forum Pool Equipment & Operations
    Last Post: 10-20-2006, 04:00 PM
  5. Leak out of backwash hose...
    By sc-pierce in forum Pool Equipment & Operations
    Last Post: 08-02-2006, 10:45 PM
