Closed Thread
Thread: Question about the size of a leak
    Default Question about the size of a leak
    I have been searching for a small leak in my AGP since i opened if for the season. It is a 15x24 oval and i was losing about 1"- 1 1/2" over the course of a week. I found a small leak today, basically a pinhole. My question for the experts, is, could a leak that small caused my water loss? Or should i be looking for something else.
    Honesdale PA
    Default Re: Question about the size of a leak
    A small pinhole could easily cause your water drop. That's only around 300 gallons or less....rough estimate. Curious how you found it.
    Quote Originally Posted by Poconos
    I was going to go around the bottom of the pool and work my way towards the middle with the mask. I was looking real close to any where the liner had a little give, figuring it could be from the sand washing away. I found one small section where there was a black dot in my first time around at the base of the wall . When i pushed on the liner the dot changed to white. The liner was a bit off the cove and when i pushed it to the wall i could see the white of the wall inside.
Closed Thread
  1. Question about using the bucket method to determine if I have a pool leak
    By JohnASmith in forum In-Ground Pool Construction and Repair
    Last Post: 04-14-2012, 09:12 AM
  2. Pool leak question
    By bradm49 in forum In-Ground Pool Construction and Repair
    Last Post: 10-01-2011, 11:08 AM
  3. Hard Plumb Question & Size
    By jrv331 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-17-2009, 07:48 PM
  4. Solar Cover Size Question
    By msjulian in forum Pool Equipment & Operations
    Last Post: 06-04-2008, 12:36 AM
  5. air leak question
    By boomer99 in forum Pool Equipment & Operations
    Last Post: 05-16-2007, 02:06 AM
