Thread: quick question about vacuuming with sand filter.
    rnjng Guest
    Default quick question about vacuuming with sand filter.
    I keep seeing I need to vacuum to waste. Do I need to vacuum to waste if all I'm vacuuming is stuff you can see along the creases and wrinkles(touch up vacuuming), or can I keep it on filter while I touch up.
    Honesdale PA
    Default Re: quick question about vacuuming with sand filter.
    I'd use it in filter mode simply to conserve water. If the stuff is so fine that the filter doesn't trap the particles then you can try the DE in the sand filter trick. That trick has been discussed quite a bit but if you can't find a thread, post back and I'll dig one up.
    Heartland
    I've never had to vacuum to waste. I, like Poconocs, vacuum in the filter mode. The way I understand it you really only need to vacuum to waste when your pool is really messed up (lots of algae, leaves, dirt, etc.)
    rnjng Guest
    thanks, I never read anything about not vacuuming to waste. thks!!!!!!
  1. New Quick set pool with New ebay sand filter system, low pressure
    By trickedout in forum Intex-type Pool Setup & Operations
    Last Post: 08-08-2012, 11:34 PM
  2. vacuuming sand in pool...
    By resp215 in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-05-2011, 03:27 PM
  3. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 08:36 AM
  4. need tips on vacuuming out sand
    By dhfsmith in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-14-2008, 11:28 PM
  5. Changing Sand in Filter and Random Filter Question
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2006, 02:38 PM
