Hello Friends!
I'm a newbie who found this forum by searching on my many Baquacil problems. Due to an out of control yellow algae outbreak we're converting to chlorine using instructions from our pool company. I can already hear the groans, having been reading here for awhile now!
I have a few questions, if anyone would be kind and patient enough to go over this same ground yet again!
Ok, my pool is 25,000 in-ground vinyl. We just traded out Zeobrite for sand in our Hayward filter in hopes that the change would help with the algae problem, which it didn't, so now we're converting.
The pool company sold us a product called GLB X-change, which we broadcast into the pool and we're now on our second 3" chlorine tablet. We began this on Friday PM.
There is very little noticable change. The water was already a neon green due to the algae build-up. It's gotten a tiny bit lighter, but barely. We cannot see the bottom on the deep end and the water is fairly cloudy. The algae is still flourishing. We've been sweeping every day, and the algae is right back again.
There is no noticable change in filter pressure, although we are backwashing once a day anyway.
We haven't had the water tested again, but a baquacil test strip shows our sanitizer level to be very low, ph about 7.5 and alkalinity about 120. I know these strips to be unreliable, however. Pool company wants to test once this second tablet is dissolved, which will be tomorrow it seems.
Naturally, having read these forums, I'd like to go with bleach at this point. I'm getting the sense that we'll be at this forever if we continue with the pool co program. I'm sure though, that they won't do our water testing for us once they know we're going this on our own. I have ordered a chlorine test kit from pool solutions, but I probably need something more comprehensive, if I'm reading correctly. I'm not sure when that will arrive, I ordered on Saturday.
OK, here are my specific questions:
What pool test equipment should we have before beginning to add bleach?
Will the bleach get rid of the algae, or are we going to have to deal with that separately?
Will we need to replace the sand in our filter once the conversion is complete? The sand is right now less than one week old.
Is it safe to go in the pool during the conversion?
Thanks so much to anyone who can answer these questions!
