Thread: Pool start up?
    Default Pool start up?
    We are currently in the process of filling our new pool (We finally did get the pool up, but that is another story)
    We have an AG 41x21x52" oval about 20500 gal.
    22" sand filter, with 1.5 HP pump
    AquaRite SWG will be here Wednesday, suposedly
    I do have a drop based OTO cl test, and am planning to upgrade to Ben's kit very soon...
    Should I used the stablized Chlorine tabs that came with the pool kit to get the pool running, and establish some CYA in the pool while I wait on the SWG? Is this a good plan? What would you do?
    TIA!
    PatL34 is offline Lifetime Member Widget Weaver PatL34 2 stars PatL34 2 stars
    Saint Cloud, FL
    Default Re: Pool start up?
    Use the tabs until the the CYA level is between 60 - 80 ppm, and then start using regular bleach to maintain about 5 ppm chlorine. TA should be 80 - 120 ppm, and CH can be a nominal 120 ppm.
    Add muriatic acid to maintain about 7.2 to 7.6 pH. Add the salt with at least 99.5% purity, (not rock salt) for the pool size you have. You can get it from Home Depot or Lowes.
    Use mwsmith2's bleach calculator below to help you calculate the amount of salt required, and any other chemicals.
    http://home.earthlink.net/~mwsmith70...achCalc262.exe
    Hope this helps to get you started.
    Pat
    20,000 Gallon IG Diamond Brite pool, 1.5 HP Sta-Rite pump, Hayward Microclear DE3600 filter, Favco solar panels, Poolpilot DIG-220 with SC-48 cell.
    + SWCG OPERATION thread here: http://www.poolforum.com/pf2/showthread.php?t=1226
    + SWCG Running Costs post here: http://www.poolforum.com/pf2/showthread.php?t=316
    + Effective Stabilizer addition post here: http://www.poolforum.com/pf2/showthread.php?p=6645
  1. Where to start? BBB pool!! HELP!
    By HollyClo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2011, 10:15 PM
  2. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
  3. New pool start up
    By micon2 in forum DPD-FAS based testing
    Last Post: 10-20-2006, 11:54 PM
  4. Pool Start Up
    By micon2 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-07-2006, 10:52 AM
  5. New AG pool-How To Start???
    By rferrel1 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-22-2006, 07:19 PM
