Results 1 to 10 of 29
Thread: algea in pool
    Jul 2006
    long island, ny
    Default Re: algea in pool
    ok. so things are ok so far. pool looks a little less green i think. i backwashed this am and a lot of green came out so thats good. levels are still holding. ph is at 7.2 and i dont want it to drop so how much borax would i add to increase it if needed? I might just leave the cya alone for this season since only about a month or so left. once i get the pool blue and cleared up, do i still need to maintain a fc at 15-20? if so, is that safe for people to swim in? thanks
    PH is OK at 7.2, but if it drops any, add Borax slowly so you won't get it too high. I'd probably do no more than a fourth of the box at a time.
    Keep your chlorine at shock level. Glad it is looking better - but keep hammering it with bleach. Test it at least 3x a day and each time, take it back up to shock level.
    After the pool is cleared, keep the high cl for one extra day as insurance and then you can let it drop back down. But, with cya of 70, you'll want to keep it between 5-10 ppm all the time and yes, it is safe to swim in at that level.
    Jul 2006
    long island, ny
    ok...so ive been testing the water at least 2 times a day. the ph is staying at 7.2 and the fc is at least 15. i tried diluting it a little more and multiplying by 4 and it was still very yellow. the pool cleared up dramatically where it is now clear, but still a little green. ive been adding 1.5 gallons of bleach daily, backwashing daily and vacuming daily. I got up A LOT of algea. so, how much longer do you think before the pool is blue again? also, how do you guys feel about the phos free solution to keep algea from feeding? thanks for all of your help.
    duraleigh Guest
    Tara,
    I am pretty sure you are not using enough bleach. 1.5 gal daily will only raise your pool 6ppm. I don't know where your chlorine level is now but, if you'll post that, someone here will advise you on how much more to add so your pool will clear more quickly. My guess is the delay in clearing your pool is not getting your chlorine high enough.
    Save your money on that Phos Free stuff...you don't need it....you need chlorine.
    Oops! I misread your post. I see now where you say your Cl is around 15ppm. That's good. Be sure to check it again this evening and add enough to bring it right back to 15ppm...a little higher won't hurt....Did you ever determine a more accurate CYA level?
    Jul 2006
    long island, ny
    according to the walmart drop set, my cya is around 70-90. i just tested the water, this time diluting 4:1 and multiplying by 5 and it is still very yellow. so, probably at least 20. i dont know how unaccurate it becomes the more you dilute it, but it is not getting any less yellow. with a vinyl liner, im afriad to put too much bleach in the pool.
    duraleigh Guest
    Yeah, you don't want to go crazy with the bleach. It sounds like you are just about at the right level.
    Do your best to keep it right at that level and I think you'll see some pretty dramatic improvement in the next day or so. As a reminder, keep running your pump 24/7 'til your water is nice and clear.....I think you're pretty close.
    Jul 2006
    long island, ny
    sorry, but i have yet another question. the pool is slowly clearing up as i said before, but it seems to have stopped. its clear, but light green. when i vacuum, it gets green again, and cloudy but then clears up. In the past, we have used first aid to help clear up the pool. We have the blue stuff now. should i use that to help things along or just wait it out? I seem to be adding 1.5 gallons of bleach daily and just maintaining this color now. what else can i do? im getting frustrated!!!!
  1. Intex Sand Filter Problem- i vacuum dead algea from pool floor & it keeps coming back
    By polockma in forum Intex-type Pool Setup & Operations
    Last Post: 08-05-2012, 04:02 PM
  2. Opening pool with massive algea growth
    By TomDehoff in forum Dealing with Algae & Slime
    Last Post: 06-01-2012, 05:22 PM
  3. Close with algea??
    By jagwire22 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-21-2010, 06:36 AM
  4. Drained our IG pool b/c of continual algea problem
    By lovedisney in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2007, 10:06 PM
  5. First algea in new pool/spa
    By mkelley in forum Dealing with Algae & Slime
    Last Post: 07-25-2006, 06:56 PM
