Thread: Newbie with first-time test results
    Jul 2006
    Maryland
    Default Newbie with first-time test results
    I have a 20,700 gal outdoor plaster pool with a salt chlorine generator in dallas TX.
    Using the PS-234s I got the following:
    FC: 7
    CC: 0
    pH: 7.6
    Alk: 170
    Cal: 360
    Cya: 70
    Salt: 3200
    I I need to lower my alkalinity by 50, but I think adding 2+ gallons of acid might put my ph out of whack. What do you recommend?
    Sun Prairie, WI
    Default Re: Newbie with first-time test results
    If you are looking to lower your alkalinity I would recommend looking at this sticky: http://www.poolforum.com/pf2/showthread.php?t=191. It works great.
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
  1. First time test results...
    By freddyttt in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-29-2008, 12:34 PM
  2. First time test results for pool
    By tbatti in forum DPD-FAS based testing
    Last Post: 07-13-2008, 10:29 AM
  3. First time PS234 Test Results
    By Mr Bill in forum DPD-FAS based testing
    Last Post: 07-10-2006, 04:28 PM
  4. 1st Time Test Results
    By vanduse1 in forum DPD-FAS based testing
    Last Post: 06-16-2006, 12:51 AM
  5. 1st Time test results
    By Bnelson in forum DPD-FAS based testing
    Last Post: 05-29-2006, 03:16 PM
