Results 1 to 10 of 16
Thread: New Pump Tripping Breaker In House
    Default Re: New Pump Tripping Breaker In House
    The new motor is 115 volts and 12 amps. So I shouldn't have to change the breaker, right?
    Orlando, Florida, USA.
    The breaker may be weak so it may still need to be changed but I would look elsewhere for a problem.
    FYI, you should also check that the wire into the breaker is tight. A loose wire will cause heat build up and increased resistance. You should periodically check all the breaker screws to make sure they're snug - but don't do this with any power on at the breaker.
    You should not simply replace a 15 amp breaker with a 20 amp, unless the wire size is 12. I cant imagine someone using 14 gage wire (15 amp) for a pool but you should check before replacing the breaker.
    Thanks for the advice everyone. I purchased a 15 amp 115 volt extension cord and it's working great. Now I need a fixed outlet.
    Thanks!
    Another stupid question. The pump doesn't seem to have an on/off switch. Do I need an electrician to wire one?
    Thanks!!
    Covington, LA
    you'll want to get a outdoor timer for your pump and it will have an on off switch on it.
    This is just a sample i have never bought anything from these people. http://www.intheswim.com/Pool-Filter...e-Ground-Timer
  1. Hayward 1.5 HP pump tripping breaker
    By fjd726 in forum Pool Equipment & Operations
    Last Post: 07-08-2012, 04:53 PM
  2. Pump popping breaker.
    By 737Mech in forum Pool Equipment & Operations
    Last Post: 06-14-2012, 12:38 AM
  3. 2 speed pump trips breaker
    By NEPApoolguy in forum Pool Equipment & Operations
    Last Post: 10-15-2011, 09:29 AM
  4. what kind of breaker to use for filter/pump?
    By rastoma in forum Pool Equipment & Operations
    Last Post: 05-16-2009, 04:42 PM
  5. New pump and motor=tripping breaker
    By poolboy69 in forum Pool Equipment & Operations
    Last Post: 07-18-2008, 04:59 PM
