Results 1 to 4 of 4
Thread: PH low after adding my cya- how to adjust?
    Jul 2006
    Red face PH low after adding my cya- how to adjust?
    Did my conversion in less than 2 days and my pool is beautiful; however, this morning my ph was down to 6.8 after adding 4 lbs. of CYA in the skimmer. The bleach calc says to add soda ash to raise it and other threads say to use borax. I am totally confused as to what to add. What is soda ash and where do you get that? Also , is this normal that the cya lowers the ph?
    My pool is an IG 18000 vinyl liner. Had to use test strips and they are hard to read, but I haven't gotten the kit I ordered from Ben yet ( which was only 4 days ago). Should I get a drop based from Wal-Mart in the mean time or can I continue with the strips and guess at their accuracy?
    CH 1
    Ph 6.8 (yesterday 7.6)
    AlK 100
    CYA - don't know yet
    Help! Linda
    P.S. I used a kitty litter scoop to clean a lot of the gunk out of my sand filter until I can change the sand. It worked really well because the globs stay in the scoop and the sand just falls through when the filter is not drained of water. (Sorry if this tip is in the wrong thread-I am a newbie)
    PatL34 is offline Lifetime Member Widget Weaver PatL34 2 stars PatL34 2 stars
    Saint Cloud, FL
    Default Re: PH low after adding my cya- how to adjust?
    Add the Borax. It does a much better job than soda ash. Soda ash is sodium carbonate. CYA is cyanuric acid and will lower pH, but not as much as muriatic acid.
    Yes, get the drop-based test kit from Walmart, or the Taylor K-2006 kit from the pool store. Ben's PS234 testkit will do everything you need for testing. We here find test strips to be very unreliable, and some of only use them to get ballpark figures.
    Hope this helps.
    Pat
    20,000 Gallon IG Diamond Brite pool, 1.5 HP Sta-Rite pump, Hayward Microclear DE3600 filter, Favco solar panels, Poolpilot DIG-220 with SC-48 cell.
    + SWCG OPERATION thread here: http://www.poolforum.com/pf2/showthread.php?t=1226
    + SWCG Running Costs post here: http://www.poolforum.com/pf2/showthread.php?t=316
    + Effective Stabilizer addition post here: http://www.poolforum.com/pf2/showthread.php?p=6645
    Jul 2006
    Thanks Pat- So how much Borax do you add if you can't use the bleach calc to figure it out? 18000 gal to raise .4 to .6?
    duraleigh Guest
    Hi, Linda,
    Borax comes in the same size box country wide. So, a good start would be to add 1/2 of the box, wait around 24 hours and retest. Re-add based on your test results.
    The Wal-mart kit ($15) is a good stop-gap kit...much better than the strips. The Taylor kit is a good kit but way too much money ($60 or more, I think) if you've ordered Ben's. His will be worth the wait.
    CYA would not have lowered your pH that much. I suspect it's the inaccuracy of the strips.
    The kitty liter scoop is a nice tip,,,,makes sense.
  1. How to adjust CYA down
    By l8nite4me in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2007, 03:27 PM
  2. How to Adjust pH and TA
    By iwannapool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-15-2007, 04:22 PM
  3. What should I adjust ?
    By aswetich in forum DPD-FAS based testing
    Last Post: 07-27-2006, 06:33 PM
  4. Adding Stabilizer to adjust CYA
    By waltham41 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 01:52 PM
  5. Should I adjust anything ?
    By aswetich in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-02-2006, 08:34 PM
