Don't be afraid to hit it with a pipe wrench a bit. Just be careful, there is no reason for you to only go hand tight.
except i tried and no luck gripping that sucker with a pipe wrench..just slipped right over![]()
Are your pipe wrenches worn out?
i don't think so..haven't used it that much..maybe i didn't tighten enough due to worry about wrecking the nipple![]()
Teflon tape does almost nothing when used in 2 layer applications, 5-8 is MUCH better.
I've found that the only way a pipe wrench slips is if it is being used backwards, it does not compress that way.
Wrap some duct tape around the outside and grab it with your pipe wrench.
As a former plumber (sort of) I will say that the recommended times around with teflon tape that I have heard of is 6.
If pipe wrench is not working, you may have to upset the misses and grab her jar opener pad. Place it in between the pipe and the pipe-wrench or channel locks. I have used that technique over and over. Should get you tight enough to stop any leaks. Good luck.
Use teflon sealant paste, not tape. I just installed a heater also and I found the tape was causing a little leak where it connected to the copper pipe.
