Results 11 to 14 of 14
Thread: can anyone help re: C-PVC HEATER 'NIPPLES' QUESTION
    Morris, IL
    Default Re: can anyone help re: C-PVC HEATER 'NIPPLES' QUESTION
    As a former plumber (sort of) I will say that the recommended times around with teflon tape that I have heard of is 6.
    thanks guys..i think i've basically got it..managed to get the pipe to grab and put about 4 turned around..one still leaked just a touch..but it was so little i was able to put a smear of silicon on it and it isn't leaking anymore..came back from my vacation and no leaks (it was running 12 hours a day so a good test)
    Jul 2006
    Pearland, TX (Houston suburb)
    If pipe wrench is not working, you may have to upset the misses and grab her jar opener pad. Place it in between the pipe and the pipe-wrench or channel locks. I have used that technique over and over. Should get you tight enough to stop any leaks. Good luck.
    Use teflon sealant paste, not tape. I just installed a heater also and I found the tape was causing a little leak where it connected to the copper pipe.
  1. heater question
    By poolhelp101 in forum Pool Equipment & Operations
    Last Post: 05-30-2013, 02:28 PM
  2. Heater question
    By Pamsel in forum Pool Equipment & Operations
    Last Post: 06-08-2007, 09:49 AM
  3. Heater Question
    By halefmly in forum Pool Equipment & Operations
    Last Post: 11-26-2006, 02:46 PM
  4. Heater Question
    By CanuckPool in forum Pool Equipment & Operations
    Last Post: 10-04-2006, 11:19 AM
  5. heater question- what's your take?
    By tenax in forum Pool Equipment & Operations
    Last Post: 08-19-2006, 09:13 AM
