Results 1 to 10 of 83
Thread: The Great Tetraborate Experiment!
Threaded View
  1. #13
    Default Re: The Great Tetraborate Experiment!
    Weekly pool test....not much had changed
    FC 5.0 ppm
    CC 0 ppm (no change)
    pH 7.5 (Usually up to about 7.6 after a week)
    TA 120 ppm (before stabilizer correction) (no change)
    TA 97 ppm (after stabilizer correction) (no change)
    CH 220 ppm (no change)
    CYA 70 ppm (no change)
    Salt 3600 ppm (once again using the display on the Aqualogic.
    Salt 3550 ( AquaChek White salt test strip)
    Borates 50 ppm
    Pool is clear, clean, and sparkling. Have company for the week. My Nephew, his wife, 1 grand niece and 2 grand nephews are coming in Sunday so the pool will be getting a lot of use. We will see what happens.
  1. Measuring sodium tetraborate (borax)
    By Rebecca in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-15-2012, 07:11 PM
  2. Post tetraborate experiment maintenance
    By kelemvor in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-09-2012, 02:16 AM
  3. DPD powder experiment
    By Poconos in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 11-23-2006, 01:27 PM
  4. How to test for sodium tetraborate?
    By Calicowinks in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-05-2006, 01:25 AM
  5. Sodium Tetraborate
    By bassadict69 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-21-2006, 12:38 AM
