Thread: Help My Pool is Really Green!!!
    Jul 2006
    Default Help My Pool is Really Green!!!
    My pool has been green now for about three days and I can not get it clean. I have added algaecide and shock it to it, but it doesn't seem to be doing anything. I am reading information about adding bleach to your pool, but I have always been told not to this because it would weaken my liner. What should I do. My chlorine level is normal, but my pH is low, which is normal for my pool. I have never had it be in needed range since I have had my pool. Can someone please help me, we are missing some really good pool days.
    Sanford, FL
    Default Re: Help My Pool is Really Green!!!
    1. We cannot tell you what to do without your numbers. "Normal" to the pool store may be the problem. Please post FC (free chlorine), TC (total chlorine), PH, ALK, CA, and CYA.
    2. What did you "shock" with?
    3. Bleach=chlorine. Chlorine comes in many forms - bleach is one, pucks are one, shock is one, liquid chlorine is another, and so on. Most have other ingredients that can affect your pool - bleach doesn't have all the "extras" (extras can cause problems).
    Once you have posted your numbers and you have a DROPS based test kit - (you can get a 6-way test kit from Wal-Mart for about $15 OR better yet get a good Taylor kit or Ben's kit on http://www.poolsolutions.com) - then we can tell you what to add and when.
    **The low PH will hurt your liner - not chorine from bleach**
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 12:51 PM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
  4. green pool: like black/green pool
    By bazman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2010, 11:25 AM
  5. green green pool
    By mr greenpool in forum Dealing with Algae & Slime
    Last Post: 07-09-2006, 02:04 PM
