Closed Thread
Thread: ? about # of returns needed
    Dec 2005
    Default ? about # of returns needed
    For a small 3800 gallon inground rectangular gunite pool with 2 skimmers and in floor cleaning system - how many returns would one expect? I'd really appreciate any proposals or approximations from those in the know.
    duraleigh Guest
    Default Re: ? about # of returns needed
    3800 gallons? That would be 12' x 10' x 4' deep. Either a typo or a math error, I think.
    Dec 2005
    It is about 19' X 9' with a very small tanning ledge and spa within those dimensions. A courtyard dipping pool.
    duraleigh Guest
    Normally two returns would be perfectly adequate.
    I'm not positive but I think those in-floor systems like a lot of flow. That may dictate a pretty good size pump and, subsequently, perhaps an extra return. Your PB should have all the calcs he needs to size that system properly with the in-floor. If you're the PB, you need to speak with the in-floor manufacturer.
    Dec 2005
    I found out we don't need any returns. The system circulates the water and the debris heads to the skimmers and Caretaker drains. We do have one return to use temporarily in an emergency should something fail with the in floor system. I am looking forward to see it up working soon.
Closed Thread
  1. Bubbles from my returns?
    By gilbertpsk in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-17-2011, 04:31 PM
  2. Iron Stain Returns
    By BobbyC in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-12-2007, 10:58 PM
  3. Returns Stuck
    By Wolffe in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-02-2006, 08:35 PM
  4. Lighting and Returns Question (pic)
    By jhershauer in forum In-Ground Pool Construction and Repair
    Last Post: 07-02-2006, 11:27 AM
  5. Returns
    By crosso in forum In-Ground Pool Construction and Repair
    Last Post: 06-01-2006, 05:26 PM
