I know this is going to sound like "The same ole poolforum standard answer" but If I were you, I'd add more bleach. Now that you have Ben's test kit, you will be able to accurately monitor your FC levels. Bring your FC up to shock level and HOLD it there for a couple of days. I would think this should help. Have you ever put anything with copper in your pool? The reason I ask is that staining may occur if you have so shocking may not be the answer in this case.
Dave
P.S.- On another note, I won't use anyone BUT Fed Ex. They are a little more expensive, but when you've got to have it there on time......![]()
