Thread: PH and TA problem
    Default PH and TA problem
    My TA is 140 and my PH is 7.2
    How do I lower the TA without lowering my PH?
    6600 gallon fiberglas pool
    duraleigh Guest
    Default Re: PH and TA problem
    Leave it alone....pH is perfect and Alk is just fine.
    If you are convinced you need to lower Alk, read the sticky on how at the top of the Alk forum.
    Thanks to all for the help
  1. Please help...never had this problem before
    By Mattcef in forum Dealing with Algae & Slime
    Last Post: 06-19-2012, 08:36 PM
  2. Having a problem we never had before.
    By Hadestech in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-26-2011, 08:24 PM
  3. Algae problem or fliter problem ?
    By ROBIN13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 03:29 PM
  4. PH problem. Help.
    By bookworm in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-18-2006, 09:18 PM
  5. New Problem...
    By Dafreak in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2006, 10:05 AM
