Results 1 to 8 of 8
Thread: Storing Clorox
    Cedar Hill, TX (Dallas)
    Default Re: Storing Clorox
    Quote Originally Posted by JimSentry
    My CYA is over a 100 but I don't want to drain until next year when I replace the liner.
    With your high CYA, you don't want it to go higher... I would use bleach and save the pucks for vacations and after you lower CYA.
    Jan 2006
    Atlanta
    What are the adverse effects of a high CYA?
    Northern Kentucky
    Mostly you will have to keep very high chlorine levels in your pool for the chlirine to be effective. CYA, while helping to keep the chlorine in your pool, also decreases it's effectiveness.
    According to Ben's Best Guess table, you need a minimum FC reading of 8ppm, max of 15ppm, and shock at 25ppm.
    As you continue to ues pucks, your CYA level will rise, and so should your FC.
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
  1. storing solar cover on rail
    By lsasso in forum Above-Ground Pool Construction & Repair
    Last Post: 08-22-2011, 07:14 PM
  2. Storing and re-using Taylor's reagents
    By Water_man in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 10-12-2008, 11:02 AM
  3. storing muriatic acid
    By Michaela521 in forum Pool Chemicals & Pool Water Problems
    Last Post: 10-24-2006, 10:46 PM
  4. Storing Chlorine
    By ePoolUser in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-10-2006, 04:40 PM
  5. Storing Test kits ? Inside or outside?
    By mrmrk49 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2006, 09:16 PM
