Thread: 2.75 inches of rain in 2 hours--dirty pool!
    Jul 2006
    Default 2.75 inches of rain in 2 hours--dirty pool!
    I had my pool looking really good running:
    12.0 c
    12.0 FC
    150 cya
    7.4 ph
    I was swimming at 8 PM and shortly after I got out, a huge monsoon storm came in and dumped almost 3 inches of rain. The pump ran all night, however the pool is still dirty brownish greenish looking. I took a DPD reading and my FC was at 5 this morning. I backwashed and added about a gallon of bleach this morning and left the pump running. Is there anything else I should do? I will take a reading when I get home tonight.
    Thanks.
    Morris, IL
    Default Re: 2.75 inches of rain in 2 hours--dirty pool!
    That pool needs to be drained and refilled doesn't it? If you did it half way you could get it down to 75 I think, which is closer to normal. The needed chlorine is higher with that amount of CYA for sanitation.
    Saint Cloud, FL
    I am having a problem when I see CYA readings of 150 ppm from some water analyses lately. The test I use can only go up to 100 ppm. These readings need to be qualified more accurately, granted that is a very subjective test.
    The moment 150 ppm CYA is mentioned, the consensus seems to want to drain the pool. WHOOOOOOA. Draining water is a big decision and should not be taken lightly.
    Testing CYA levels IHMO is not taken seriously enough, because it is very subjective. IMHO it is the most important test to be done, as it appears not affected by any other chemicals. As such I would like to see a standard set up in this forum for testing CYA levels. For what it is worth, this is what I do.
    1. Purchase the large sampling tube with the plunger that has the black dot on it.
    2. Buy a gallon of Taylor R0013 reagent, and small sampling bottle to put some of the reagent in. I keep this in the bathroom under the sink, where there isno light 95% of the time.
    3. Make sure the sampling tube is scrupulously clean. Use an old toothbrush if necessary, or straight bleach.
    4. Add the pool sample to the A mark, and R0013 reagent from the small bottle to the B mark.
    5. Wait at least 1 minute before taking the reading.
    6. This is important. Face a North facing window, holding the sampling tube by the base so as not to interfere with any light from the window. If you face the sun, there might be extra light coming in to affect the reading.
    7. Slowly raise the plunger, and as soon as you see the black dot, that is your measurement. If you are not sure of the measurement, or don't believe it, have someone else take the reading again. If you agree, then that is the reading to use.
    Hope this helps.
    Pat
    Jul 2006
    I don't want to drain it until the winter when I retile and resurface the pool. It is an inground gunite pool 20 yrs. old with a large sand filter...
    The best I can tell is that the cya is 150. That is what I deduct from the PS234 test and the reading from one local store. I took it to a major chain store and they said it was 235! So I will base the chlorine on the 150. This is my first pool and I have been using the trichlor pucks for 2.5 years, after I had the pool refilled.
    I just checked the pool and the Cl is at 10. I will take it up to 25 in a few minutes. Thanks for all your help.
  1. new intex pool - how many hours should filter run daily?
    By springtunnel in forum Pool Equipment & Operations
    Last Post: 07-19-2011, 11:41 PM
  2. Clear Pool after 48 hours of filling
    By kristen in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-26-2011, 10:03 AM
  3. pool leaking a couple inches a day
    By wverbest in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2011, 02:31 PM
  4. 10 inches of RAIN in pool, now what??
    By poolmom06 in forum General Interest
    Last Post: 07-05-2007, 04:31 PM
