Been in a similar there, done a similar that.........more than once!!
Dave,
Just an update, was away for a week so I put the pump on a timer (was not running it 24/7, got home to a little dirt so I hooked up the cuda and sure enough pressure was back to a little under 15psi and the cuda was climbing walls like I knew she could. So either the pump needed a break or whatever may have been clogging things cleared. I am going to check the pump basket tonight to see if anything dumped out into it.
Thanks again!
