Results 11 to 20 of 22
Thread: How do you add muriatic acid?
    mohawk is offline Registered+ Thread Analyst mohawk 0
    Minneapolis, MN
    Default Re: How do you add muriatic acid?
    Newpoo, that's funny-Neil Armstrong. I was wearing shorts when I poured the acid in-maybe it'll be long pants from now on. Denise
    .warren, michigan
    Smile Re: How do you add muriatic acid?
    I always pour the acid into a old glass canning jar. They have measurements on the side of them and are easy to handle.
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    I had posted the same question about a month ago....I was loosing my shorts and shirts from splashed acid that I didnt notice.
    The recommendation was to dilute it in a bucket first then toss the bucket in the deep end.
    Since then, no new holes in my shirts! I dilute roughly 5/1 water/acid
    Some people have hobbies.....I have a pool.
    Sun Prairie, WI
    I pour it out of the jug slowly at the waterline in front of a return. I wear gloves, goggles, and a respirator (indoor pool).
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
    simsjim is offline Registered+ Thread Analyst simsjim 0
    Jul 2006
    Couldn't you substitute granular Sodium Bisulfate to low PH? Is there a benefit to the Acid that the Sodium Bisulfate wont provide?
  6. #16
    Minneapolis, MN
    I believe muriatic acid is cheaper and doesn't add sulfates to your pool. I was given certain chemicals when we purchased our pool and sodium bisulfate was one of them. I used 2 3lb containers in the pool and it only brought down the ph by 2 points. When I first used the muriatic acid, I poured approx. 3/4 c into the pool and it came down by 2 points. I still have a lot left in the gallon jug as compared to no more dry acid. Hope this helps. Denise
  7. #17
    Saint Cloud, FL
    If you have a SWCG, then Muriatic Acid is the only pH reducer you should be using. As Mohawk says, sodium bisulfate only increases you total TDS.
    Pat
  8. #18
    joelq is offline Registered+ Thread Analyst joelq 0
    Frisco, TX
    I'll be adding my first dose of Muriatic Acid tonight (pool just filled this past Saturday). I like the idea of measuring how much to add with a glass measuring cup. Do I rinse the cup after I pour the acid in? I would think not given the "never add water to acid" warning. Do I just leave the cup to dry?
  9. #19
    IL.
    I use a plastic measuring cup, and when I've poured all the acid in, I dip it in the pool and pour it out 4 times, making sure to get it totally rinsed, then set it aside to air dry in the garage with my other pool tools.
  10. #20
    Central Texas
    Yeah, just quickly dip the measuring cup into the pool water and empty a few times. No violent reactions here so far.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
  1. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  2. How much Muriatic Acid?
    By mccato in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-29-2006, 09:21 AM
  3. How to add muriatic acid
    By BullDean in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 11:51 PM
  4. how much muriatic acid
    By wolfcue in forum Dealing with Alkalinity and Calcium
    Last Post: 06-07-2006, 06:55 PM
  5. How much muriatic acid to add?
    By Blemished_Chemist in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-04-2006, 09:15 AM
