Results 1 to 4 of 4
Thread: Alkalinity
    Jul 2006
    NC
    Default Alkalinity
    How high is too high for a vinyl pool and what do you if it's too high?
    Thank you!
    Pam
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default Re: Alkalinity
    There is a sticky at the top of the alkalinity and calcium forum that explains how to lower alkalinity. You want your alkalinity to be between 80-120. I think vinyl liner pools can be higher than that, but that is what is usually recommended for pools.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
    Carterville,IL
    Quote Originally Posted by newbie2pools
    Thank you!
    Pam
    I just got my alkalinity ok to shock (newly filled pool-4 days now). It read 110. I have gotten it up from about 80 w/ baking soda and the ph is good. I have had chlorine sticks in ( I always keep two going) and tom. a.m I am going to shock w/ 1 lb of burn out and after 1 hour or so I will put back the skimmer basket w/ the chlorine smart sticks and see where that takes me.
    Jul 2006
    NC
    Thanks you!
  1. Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    By heyaim in forum Dealing with Alkalinity and Calcium
    Last Post: 07-22-2012, 07:51 PM
  2. Ph or Alkalinity...which should i fix first
    By JKashJ in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-11-2008, 05:18 PM
  3. Alkalinity Low??
    By Brunomax in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2007, 03:23 PM
  4. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 09:36 PM
  5. Alkalinity FAQ
    By VickieC24 in forum Dealing with Alkalinity and Calcium
    Last Post: 04-04-2006, 11:03 PM
