Thread: Time for a new pump
    Morris, IL
    Default Re: Time for a new pump
    you could just cut the pipes and put a rubber mission coupling in there. it has two hose clamps on it that you may tighten down. Or you could cut out whatever the take off is for a Union and put it in there.
    White Plains, NY
    Thanks. I was figuring something like a rubber sleeve with clamps.
    Honesdale PA
    Similar to the rubber couplings mentioned by sevver I use straight sections of auto radiator hose of the right diameter and hose clamps. Stuff is reinforced and designed for high temperature and 15 psi pressure and seems to last forever. Probably 6-7th season on mine now and no noticeable deterioration.
  1. Pump run time
    By jackinlv in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-02-2011, 06:12 PM
  2. Pump Run Time Question
    By swilson in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2010, 08:01 PM
  3. Pump Time
    By rydablrv in forum Pool Equipment & Operations
    Last Post: 05-25-2010, 06:00 PM
  4. Pump run time in winter
    By tropic in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-22-2006, 09:22 PM
  5. Pump run time
    By newtopools in forum Above-Ground Pool Construction & Repair
    Last Post: 06-16-2006, 12:40 PM
