Thread: Led Light Question
    DONNIE is offline Registered+ Thread Analyst DONNIE 0
    Jul 2006
    Oklahoma
    Default Led Light Question
    New 12 x 25 fiberglass kidney. Can't decide on lighting. 300 watt white light would be pretty and probably provide plenty of light but pool guy wants to install 2 LED's at $400+ each. Are LED's going to be as bright as a 300 watt light? I just want the pool to "glow" at night for effect more than light. Could 1 LED be enough?
    Donnie
    Default Re: Led Light Question
    Led's are bright, but do not "throw' the light very far, so essentially you get good light up close, but a good glow all over (within a certain space), I believe he wants to install 2 on opposing ends so the whole pool is covered evenly and looks good. Personally, I would go with the LED lights, you will NEVER EVER have a problem with them unless it's wiring related, where the 300 W light will burn out frequently, waste a ton of hydro and be overly bright.
    Jul 2006
    I have a 16x34 vinyl pool with a darker liner, just had the hayward colorlogic led's put in, one in the deep end and one in the shallow. All I can say, once it turns dark!! awesome!!! it has 5 lights, blue and purple pink are the best, I dunno who would swim in red and green. and 7 I think preset programs that blink and fade and flash, very very cool!!
    Whitby, Ontario, Canada
    Anyone heard of rainbow rays led lights ? I am having two of them installed in my pool.
    I just tried to look that one up, according to the net, rainbow rays is just a replacement bulb that has some logic built in but is extremely overpriced at over 300 bucks (if that's the one).
    But, looking for this item led me to an LED place that sells MR16 replacement lights and instead of halogen they have LED technology in them, since halogens run on 12V DC and these LED lights do as well, I don't see a problem installing one of these in a waterproof housing - according to the site:
    "They are highly suited to waterproof situations as the LED's sit inside the rim of the bulb."
    So, when my Aqualuminator bulb bites the dust, I will be retrofitting the light head with a whopping 16 dollar MR16 automatic color changing LED.
    Jul 2006
    Quote Originally Posted by CanuckPool
    i sent you a PM....
  1. Light question
    By Themadczar in forum Pool Equipment & Operations
    Last Post: 07-03-2013, 10:19 PM
  2. Pool Light Question
    By gogolion in forum In-Ground Pool Construction and Repair
    Last Post: 07-03-2013, 12:10 PM
  3. Above ground pool light question
    By LedZepFan in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2012, 10:04 PM
  4. Another Light Question
    By AmigaDude in forum Pool Equipment & Operations
    Last Post: 08-29-2011, 09:00 PM
  5. Assembly question on SAM light
    By mshumack in forum In-Ground Pool Construction and Repair
    Last Post: 07-05-2007, 08:51 AM
