Results 11 to 20 of 24
Thread: Success with Baquacil so far
    Jul 2006
    DSM, IA
    Default Re: Success with Baquacil so far
    I'm doing it. I'm coming up on 24 hours into my conversion to CL. I left the pool open and unattended over the winter. Wow, was it dirty. But apparently the BAQ crap was pretty much gone, because the pool appears to be almost converted. The water is only slightly green now and CL is hanging in there. 17K gal, used only 24 gal of 6% so far.
    Why did I do it after claiming good success with BAQ? Mostly because I didn't like the approach of the pool stores, and because I like to experiment (sick mind).
    But really, the claims of all of the others about the great success of the BBB approach satisfied me that it was worth a try. And if I don't like CL, I can convert back to BAQ (I hear laughter from future readers who have already switched to CL and liked it).
    I wanted to use SGW, but I have a AG pool, SGW not recommeded I guess.
    So now I'm configuring a simple tank / pump / timer to squirt 6% in once in a while.
    Front Royal, VA
    I took your approach and let it go at the end of the season.
    So far, I'm on day 3 using about 18 gallons. I'm only losing about 3ppm overnight, but the daytime loss is huge.
    I have filter cartridges, so it's very difficult to keep up good pump pressure after about 20 minutes.
    A ton of vaccuming along with it. I'm hoping to be done by the weekend, we'll see...
    Quote Originally Posted by baq-n-ia View Post
    Not true! Goldline Controls makes 4 units specifically for above ground pools. Go to their website and look at the AquaTrol units.
  1. With your help.. we are going from mess to success!
    By senniss in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-10-2010, 09:27 AM
  2. Success !
    By Sprocket in forum Dealing with Algae & Slime
    Last Post: 06-06-2007, 03:00 PM
  3. Success!
    By Donna's Poolboy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-14-2007, 11:53 AM
  4. Not having success with BBB in my hot tub
    By keithw in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-10-2006, 09:30 PM
  5. any success
    By trexok in forum Commercial Pool Users, Managers & Workers
    Last Post: 08-13-2006, 01:27 AM
