Results 1 to 10 of 15
Thread: Heat pump vs Propane Heater
    RochesterMark Guest
    Default Re: Heat pump vs Propane Heater
    We are putting in a 24' by 40' vinyl "free form" pool in the Rochester New York area. It 's a outdoor pool that we will winterize. Do you know the average time it takes to recover the extra cost of the heat pump? From what I have seen most heat pumps are about 2X the price of a gas heater.
    Ft Lauderdale, Fl
    It really depends on how you're going to be using your pool. On average, although the initial cost of the heat pump is about 2x, the cost savings is about 50 - 70% less than running gas. Which means you're actually able to afford to heat your pool and spa.
    The cost difference may take a few seasons, but after that, it's all savings. The other considerations are warranty, and typical replacement parts that typically take place with gas heaters (with Cupric-Nickle heat exchanger failures), whereas most heat pumps will offer a titanium heat exchanger (virtually impervious to chemical attack and most manufacturers offer lifetime warrantees on the titanium).
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    Honesdale PA
    With all due respect Sean, you're in Florida and this guy is in Northern NY. Big climate difference. 'Average' costs can be misleading in my opinion. One big factor in how long it takes to recover cost is the electric rates which vary widely around the country. Another factor is the air temperature (heat sink) when the thing is running which affects efficiency of a heat pump. I agree with you on the heat exchanger statement, but you have to also consider the other components which are about the same as a central air conditioner. I admit I don't know the answer to this one but 'efficiency' to me would mean overall cost efficiency which includes non-recurring and recurring costs figured over a multi-year time frame. I used to use propane until the price went through the roof and now I use solar. Just my nickels worth.
    Ft Lauderdale, Fl
    Al, oddly enough, the Northeastern US happens to be our second largest area of Heat Pump penetration! We realize that homeowners are not looking to keep their pools opened all year around. Rather, they are simply looking to extend the swim season, and to be able to be the FIRST to open their pools, and the LAST to winterize it. This comes out to about March/April through Sept/October.
    All heaters loose efficiency when the temps are cooler. Most standard heat pumps will shut down when the air temps fall into the low 60's because of ice build up on the evaporator coil. Hot Gas Defrost options will melt the ice and allow the heat pump to continue working down into the 20's and 30's...albeit, at a lower efficiency. I would admit though, not too many people will be using their pools or spas when it's that cold. AND if you do want your pool/spa heated at those temps, I will cede that chore to a gas heater!
    When you maintain your water temperature, the amount of heat lost overnight mostly to evaporation will depend on if you use a solar cover (20% heat loss), liquid blanket (30 - 35% heat loss), or no cover (50% heat loss).
    Basically, a heat pump that is allowed to maintain a temperature (as opposed to heating on demand) has less work to do. Although the same heat loss and recovery statement is true with a gas heater, it is just so much more expensive to maintain heat, therefore the task of the gas heater is not commonly left on to maintain heat.
    So, it is asked to increase the temps from a lower water temperature, in a quicker time frame. This is the environment for a gas heater (IMO). Perfect for spas and a pool that is not used frequently when it starts to cool off.
    The Heat Pump, again, allows you to maintain the heat, efficiently, so that the pool is always ready to use. No more waiting for it to heat up and watching that gas meter just spinning away!
    (sorry for the sales pitch).
    Sean Assam
    If you have the space, do solar AND a heat pump/gas heater. With the solar heat, and a solar blanket, you should be able to go all summer and a little beyond--in both spring and fall, with zero operating costs. Solar DOES work, but only when the sun shines. The blanket (I prefer clear thicker ones) acts like a greenhouse.
    Personally, if you have access to natural gas, rather than propane, that's a far cheaper choice. If you are talking a grill, the cost of plumbing NG doesn't pay in savings over propane. But in a 400K BTU heater, the cost savings are substantial.
    Yet, despite that, if you are talking temp maintenance, you are best to go with a heat pump--it will still be cheaper than the NG, much less the propane. Combine it with solar and a blanket and you'll have a nice, extended season.
    I just have a personal bias against gas heating--it seems there are SO many ways to recover heat cheaper and more environmentally friendly. I live in N-Central NJ and I have NO trouble keeping my pool between 85 and 95 solely with solar and a solar blanket.
    the woodlands, texas.
    mmcguire,
    IMO, with a pool/spa you'd be best served with a gas fired 400K heater if you want a quick heating spa. If you feel that the luxury of waiting time is on your side go for the defrosting heat pump.
    Solar heating and blankets do wonders on keeping and slightly escalating pool temps, but don't help on your spa.
    If you feel it's in your budget step up to a combo set up with both a gas fired heater and a heat pump. it allows you the best of both.
    I have a rather large pool and use the combo setup. I can begin my season earlier and extend it later with my heat pumps and heat my spa rapidly with the propane fired heaters.
    Thanks for supporting the industry with your new pool purchase, you'll soon find out what all the hoopla of pool ownership is all about. I promise you, having a pool at home is the best thing since sliced bread!!!
    See Ya,
    Kelly
    By the way I live in South Eastern PA and have been happy with the heatpump. Pool is kept 80-85 degrees and on average it uses less than $150/month for the pool pump and heat pump to run.
    Nice to see you back Huskey missed your posts for a while.
  1. Questions about a new propane heater.
    By smacd in forum Pool Equipment & Operations
    Last Post: 05-27-2011, 02:04 PM
  2. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 07:37 PM
  3. Need propane heater recommendation
    By DanS in forum Pool Equipment & Operations
    Last Post: 08-15-2009, 10:57 AM
  4. propane heater replacement
    By vinouspleasure in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2008, 10:58 PM
  5. Gas heater vs heat pump
    By ElleM in forum Above-Ground Pool Construction & Repair
    Last Post: 03-05-2007, 04:10 PM
