Results 1 to 10 of 12
Thread: Back From vacation
    Default Re: Back From vacation
    Hi;
    I probably would have lowered the pH some then chlorined it as I'd want to get maximum effect from my chlorine buck but that's for another time.
    I owned a pool with a liner back in the late 1970's and we got our chlorine up there unintentionally a couple of times because of algae. I can't say how high it got but we seriously overchlorinated and we got lucky and the liner was just fine but then we may not have reached your level and it was an IG vinyl liner pool so maybe that's a difference too.
    I wanted to ask if the BIL remember to feed the dogs and cats?
    Jo
    24,000 Gal IG Pool ColorQuartz Premium
    1,000 Gal Spa - 8 Jets
    System 3 D.E. Filter,
    Max-E-Therm Heater
    550 Sq Ft Heliocol Solar System
    Intellitouch i7 & Goldline Aquarite SWCG
    SAm & SAl lighting, 2-2HP pumps
    Filled 6/21/2006 Owner/Builder
    mbar's Avatar
    Ashland, PA
    Often, when you have very high chlorine levels it gives a false reading for ph. And if she added 4 gals of bleach in a 7,600 gal pool, then the chlorine was really high when she tested for ph. You can really do a lot of damage to a liner when you unintentionally take the ph below 7, and have the chlorine very high.
    Northeast PA
    Jul 2006
    Hot, Dry Texas!
    If I have that much bleach in it, why is my water still green?? Today I have vacuumed to water(twice), drained and refilled about 6 inches and back washed.... shouldn't my water at least lighten a little bit??
    My readings are exactly the same as they were this morning... well Ph has gone down a bit...
    That's a REALLY good question:
    If your pool is still green then there is no way your FC is 47. Sorry MBar, but you don't figure FC from what you add, but rather from what you measure.
    When you are fighting a serious algae bloom you'll use lots and lots of chlorine.
    Your pH reading cannot be taken accurately unless your chlorine level is down. If you are using Taylor R-0004 or R-0014 to test your pH, it will be more accurate because it neutralizes chlorine up to about (I think) 15ppm.
    If you have chlorine neutralizer drops (Theosulfate, Taylor R-0007) you can add 2 drops to the pool water in your test cell before adding the pH chem.
    You COULD bleach your liner if your FC is sustained higher than 15 for a while, but if you reach 15 to 20 in an algae-infested pool it probably won't stay there long enough to damage or even fade your liner.
    Still, you need to be able to measure your chlorine at the higher levels, especially now. You need a FAS-DPD chlorine test kit. You can get it in the PoolSolutions.com kit Ben sells--the PS-234, or the Taylor 2006, or Leslie's FAS-DPD Chlorine Service Test Kit, but only on-line.
    All three will sell you, I believe, just the FAS-DPD kit.
    Jul 2006
    Hot, Dry Texas!
    My water is looking more blue today... I am about to go test it, I will report back.... I can't believe the difference over night!! It's looking better! My son wants to have some friends over to swim this weekend, hopefully he can do that!!
    mbar's Avatar
    Ashland, PA
    Yes, I didn't take into account how fast the chlorine would be used up with the algae! I was just thinking about the amount that went in at once. I am so glad your pool is looking fine - bleach really does work every time!
    Northeast PA
    Quote Originally Posted by mbar
    Hi, If you were referring to my post's suggestion about lowering pH it was supposed to mean test and adjust your pH prior to adding chlorine. Since the chlorine had already been added it was moot.
    Jo
    Max-E-Therm Heater
    mbar's Avatar
    Ashland, PA
    jo,
    I'm sorry if you misunderstood, I was referring to the first post where poolmom06 said she was lowering her ph because it measured 8.2 - I was just making a note that when you have very high chlorine levels in the water the ph test can give a false high reading. It happened to me, luckily I remember reading that info on the forum and waited to retest my ph when the chlorine level came back down - it was normal. So if I had added acid when I thought my ph was over 8, I would have taken the ph way below 7, which is acidic and can cause damage.
    Northeast PA
  1. not sure where to put- vacation WTD
    By fiveUNDERfive in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2013, 12:51 PM
  2. Help! Left on vacation and once back pump won't prime and Guests coming over
    Last Post: 09-23-2008, 05:23 PM
  3. I'm back, baby, I'm back !!!!!
    By pool newby in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-24-2008, 02:41 PM
  4. Going on vacation...
    By poolmom06 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2006, 04:34 PM
  5. What to do for Vacation
    By MaryS in forum Pool Equipment & Operations
    Last Post: 07-09-2006, 11:36 AM
