Thread: Slow drain...take it easy
    kathgilliam is offline ** No working email address ** kathgilliam 0
    Jersey Village, Texas
    Default Re: Slow drain...take it easy
    The main drain is free of debris. Yes, we're trying to drain the pool to 50% due to high CYA. There is no debris in the basket, the water line is below the skimmers now, and I've shut the valves to the skimmers. At least I *think* they are the skimmer valves, because nothing is labeled. There are three pipes in a row, two have red valves and one black. The pool store guy told me to shut off the red ones so I did. The black one is weird, seems to open three ways, but I can't really tell what position is what. The pump is at 12:00 o'clock, a pipe to the right is what I believe is the main pipe. But I also know that the position to the right is what you have to turn on to send water to the spa.
    I feel so stupid, but I supposed I really am more ignorant. You just don't know what you don't know; you know?
    K
    Saint Cloud, FL
    K,
    You mentioned in another post that you had a lot of debris from a storm, including oak balls.
    I am wondering if there is a possibility your main drain could be partially blocked internally and starving the pump as Poolsean mentioned.
    If you can find a way using a garden hose to positively identify the skimmer and main drain returns, it will help enormously.
    The other possibility is that the pump is losing its prime by not being able to overcome the suction head needed for it to operate.
    This now mens you have to rent a submersible pump, and leave the pool pump shut off.
    Hope this helps.
    Pat
    Thanks, Sean, for your help!!! Thanks to everyone here for helping with my education. I have a service company out to help me understand the plumbing. We are sump pumping out the pool, refilling and then he is going to teach me a thing or two. (Has anyone ever heard of the Algae Blaster, a hose that goes on your Polaris???)
    Kath
  1. Backwash slow pumping?
    By kwagahoff in forum --cleanup--
    Last Post: 05-19-2013, 05:19 PM
  2. Slow leak...should I be concerned?
    By JimK in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2013, 11:15 PM
  3. Gas Heater Slow to Ignite
    By jsnyder2914 in forum Pool Equipment & Operations
    Last Post: 04-06-2009, 11:55 AM
  4. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
