Closed Thread
Results 1 to 9 of 9
Thread: If You're "thinking" It May Be Time To Change Sand In Filter
    Morris, IL
    Default Re: If You're "thinking" It May Be Time To Change Sand In Filter
    You would not gte me to put it in my flowers either. lol
    Just put about twenty five pounds in your trash a week until it is gone. I do it with dirt and stuff all the time, sod especially since I am always making the beds bigger. My garbage men probably hate coming to my house.
    Honesdale PA
    The drains in sand filters usually have something to prevent sand from draining. In my Hayward it's a 'short' lateral. When they assembled the filter at the factory they forgot to put in this short lateral. On the first drain for winterizing a lot of sand came out. I just dealt with it. Siphoned when I removed the valve assembly. When I removed the sand to do some other work I made a lateral of the right size PVC pipe and cut fine slits in it. Yeah...could have gotten one from Hayward but this was less of a hassle. Bottom line, trying to wash sand out the drain won't work. Shop vac like you used is the easiest I think.
    hmmm..garbage a bit at a time..maybe i'll put it in all those empty bleach jugs
    P, i think you are right..the drain is not simply a straight out opening..it appears to have a top and a gap all the way around in between , but i suspect it's either not big enough to let sand through or would get bunged up anyway.
Closed Thread
  1. Sand Filter & Pool Pump Sizing "Rule of Thumb"
    By mnittler in forum Pool Equipment & Operations
    Last Post: 10-02-2012, 09:52 PM
  2. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  3. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  4. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
