Thread: High Ph and high Alk - help!
    court475 Guest
    Default High Ph and high Alk - help!
    Okay - my fill water alk was 330. I added dry acid before going out of town Friday. Just returned (Sunday) and it's at 270. I just added more dry acid. But not I'm reading to adjust Ph first? It is at 8.2. Where should I go from here?
    Also, with adding dry acid, CYA and bleach today, is it okay to swim?
    Courtney
    24' x 54" vinyl A.G.
    duraleigh Guest
    Default Re: High Ph and high Alk - help!
    Courtney,
    I would suggest reducing your pH with muriatic acid....cheaper and more effective. Shoot for 7.2 - 7.6.
    I cannot comment on your bleach and CYA because you didn't give us any test results.
    court475 Guest
    CYA is 0 - pool was just filled Friday as we were going out of town. (Not good timing - installer was delayed a week.) CL is 0 as well. I added 3 qts bleach.
    Courtney
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 11:52 PM
  3. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 05:49 PM
  4. had algae, PH high, TA high, water now cloudy
    By Mom4fun in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-12-2011, 01:09 PM
