17500 gal pool 1hp pump S210T (44 gpm) ....I am hooking up a pool heater (jandy 250K) and the CPVC nipples they give you for entry and exit are 2".....
Skimmer and low suction fitting were going to be piped in 1 1/2" thru pump and filter....can I upsize to 2" for the heater and then make the return (2 returns) 2" or should I stay with 1 1/2" the whole way?
Also....is an equalizer valve a code requirement on the suction side or is just a good idea? Should I take two suction lines both off the skimmer since I have two ports in the skimmer bottom?
, installing a ballance line (if the water gets too low and the skimmer would suck air, the ballance line is supposed to keep the skimmer filled with water, unfortunately I've never seen one keep up with the pump) or install a 'reserve' line run to the filter but not plumbed into the system so that if something happens to make the original skimmer line non working, you already have a new line installed and ready to be plumbed in. I have the feeling that trying to run suction through both ports of the skimmer would cause the skimmer to draw air because the pot wouldn't be able to fill fast enough, but this is just a gut feeling I cannot see any advantage to having both ports sucking. Good luck with your pool, if you have any further ?s, ask away and someone here will do their best to help you - Waste
